Service Unavailable
Hi to all,
I have getting this error when trying to update blog user permissions on DNN 10.03.02 with DNN Community Blog V6.7.1 settings page.
I had the same issue in the past and had to do a clean install of DNN 10 and DNN Blog 6.7.1 to overcome it.
Past attempts to resolve this have been unsucessful .
Maybe someone can interpret this error?
Page Load Exception
Trevor
Forrest Ministries Australia
AbsoluteURL /Default.aspx DefaultDataProvider DotNetNuke.Data.SqlDataProvi
AbsoluteURL:/Default.aspx
ExceptionGUID:d11bb7c9-bf01-4b87-9639-456276416aeb
AssemblyVersion:
PortalId:-1
UserId:-1
TabId:-1
RawUrl:
Referrer:
UserAgent:
ExceptionHash:582a95bcac43015d3da120ec6803930bdac26b45313def19b68132073fcc0d77
Message:Failed to load viewstate. The control tree into which viewstate is being loaded must match the control tree that was used to save viewstate during the previous request. For example, when adding controls dynamically, the controls added during a post-back must match the type and position of the controls added during the initial request.
StackTrace:
InnerMessage:Failed to load viewstate. The control tree into which viewstate is being loaded must match the control tree that was used to save viewstate during the previous request. For example, when adding controls dynamically, the controls added during a post-back must match the type and position of the controls added during the initial request.
InnerStackTrace:
   at System.Web.UI.Control.LoadViewStateRecursive(Object savedState)
   at System.Web.UI.Control.LoadChildViewStateByIndex(ArrayList childState)
   at System.Web.UI.Page.LoadAllState()
Source:
FileName:
FileLineNumber:0
FileColumnNumber:0
Method:
Server Name: Plesk5200
Kind Regards
Trevor
I have found the source of this error in BlogPermissionsGrid.cs.
I have sent a patched BlogPermissionsGrid.cs to the github repo.
Trevor
