SMTP Authentication using Google Mail?
Has anyone been able to get this to work? I've got ChatGPT to output what looked like decent instructions and have fllowed them but keep getting a "Error 400: redirect_uri_mismatch" error. I'll post the instructions below...
To configure OAuth for sending emails via a Google account on a DotNetNuke (DNN) 9 website, you'll need to perform the following steps, both on the DNN side and in the Google Cloud Console. This setup replaces traditional SMTP configurations, enhancing security.
Part 1: Set Up Google OAuth for Email
Step 1: Create a Google Cloud Project
  1. Log into Google Cloud Console: Go to Google Cloud Console.
  2. Create a New Project:
    • Click the project dropdown on the top navigation bar.
    • Select New Project.
    • Name the project (e.g., "DNN Email OAuth"), and click Create.
  3. Enable Gmail API:
    • In your project dashboard, click on APIs & Services → Library.
    • Search for Gmail API and click on it.
    • Click Enable.
Step 2: Create OAuth 2.0 Credentials
  1. Create OAuth Credentials:
    • In the API & Services section, navigate to Credentials.
    • Click Create Credentials → OAuth 2.0 Client IDs.
    • Select Web application for the application type.
    • Add a name (e.g., "DNN OAuth Email").
    • Under Authorized redirect URIs, add a dummy URI (e.g., <code><a href="https://your-dnn-site.com/oauth2/callback" target="_blank" rel="nofollow">https://your-dnn-site.com/oauth2/callback</a></code>).
    • Click Create.
  2. Get OAuth Credentials:
    • Once created, you'll receive a Client ID and Client Secret. Save these as you will need them for your DNN configuration.
Step 3: Set Up OAuth Consent Screen
  1. Configure OAuth Consent Screen:
    • Go to OAuth consent screen under APIs & Services.
    • Set the user type to External.
    • Fill out the required fields such as the application name (e.g., "DNN Email OAuth") and add your website domain.
    • Add your email address and the required information under the Authorized domains section.
Step 4: Authorize Scopes for Gmail API
  1. Set Up OAuth Scopes:
    • Under APIs & Services → OAuth Consent Screen, add the Gmail API scope.
    • Add the following scope for Gmail API: <code><a href="https://www.googleapis.com/auth/gmail.send" target="_blank" rel="nofollow">https://www.googleapis.com/auth/gmail.send</a></code>.
Part 2: Configure DotNetNuke to Use OAuth for Google Email
Step 1: Access SMTP Settings in DNN
  1. Log into DNN as an administrator or superuser.
  2. Navigate to Settings → Servers.
  3. Click on SMTP Server Settings.
Step 2: Input OAuth Settings
  1. Configure SMTP:
    • SMTP Mode: Select OAuth2.
    • SMTP Server: Use <code>smtp.gmail.com</code>.
    • SMTP Port: Use port <code>587</code> for TLS or <code>465</code> for SSL.
    • SMTP Authentication: Set it to OAuth2.
  2. Client ID & Secret:
    • Enter the Client ID and Client Secret obtained from Google Cloud.
  3. Authorization Endpoint:
    • Use the authorization URL: <code><a href="https://accounts.google.com/o/oauth2/auth" target="_blank" rel="nofollow">https://accounts.google.com/o/oauth2/auth</a></code>.
  4. Token Endpoint:
    • Use the token URL: <code><a href="https://oauth2.googleapis.com/token" target="_blank" rel="nofollow">https://oauth2.googleapis.com/token</a></code>.
  5. Redirect URI:
    • Set this to the URI used in your Google Cloud setup (e.g., <code><a href="https://your-dnn-site.com/oauth2/callback" target="_blank" rel="nofollow">https://your-dnn-site.com/oauth2/callback</a></code>).
Step 3: Test the Configuration
  1. Save your settings and click Test SMTP Settings to ensure that everything is correctly configured.
  2. If successful, DNN will now use Gmail via OAuth for sending emails.
For anyone having a similar problem, I was able to figure out the issue. I don't see it documented anywhere, but this is the redirect_uri you need to setup from your Google Cloud Authorized Redirect URIs field for your Credential. If for some reason it's different, you can check the web browser console network tab to see the redirect_uri field filled out after you tap the Authorize button in DNN.
https://www.[yoursite...eMail/Authorize.aspx
Posted By PeteyBlah on 10/3/2024 6:24 PM
Ah, right, that's the same for Exchange.
Thank you for posting the solution, very helpful for future users. :-)
Just to follow up, it appears it's still authenticating with the original SMTP email address I had.
The 'X-Google-Original-From' header in the email is showing the original email address.
Has anyone had that happen before, or know how to fix it? Or even debug it?
Also, where is the "from name" being set? I can't find it anywhere in the settings and the emails (new registration, password reset, etc) still have the original from name being set?
I changed a superuser Display name, and that seems to have changed the from email display name, is that really the place it's pulling that from? Why? I see in instructions in various places, that there used to be placed to change the from email name, but I don't see that anywhere in the settings anymore. Is it also pulling that email address from the super user email address? Is there some legacy setting enabled after updating from dnn7 that is causing this? Anyone have any ideas? Thanks.
Posted By PeteyBlah on 10/9/2024 3:44 PM
The email used comes from the HostSettings Table and AFAIK there is not edit interface for that and some other settings related to the main Host in the Persona Bar:
HostEmail
HostPortalId
HostTitle
HostURL
I have those host settings saved in my host settings table.
My registration and other emails still list the (X-Google-Original-From) header as coming from my superuser email.
And the "from name" is set from that superuser as well, even though those host settings are set.
