Tasks Scheduler
Hi
Not seeing the wood for the trees here?
What is the proces to change a host level scheduled task.  Have tried what seem the sensible things to do and the documentation is somewhat limited.
For example change the timing for a task from every ten minutes to every sixty minutes, or to disable the task scheduled running.
thanks
Settings => Scheduler
select the Scheduler tab
Add or edit tasks that run here.
OK have that, its just when I make the change it doesn't seem to save it?
maybe an issue to report on github
Have reported as an issue on Github
