Timeout Issue When Opening a Link
Jie
Hi Community,
I’m encountering a timeout issue when opening a specific link on a page, and I haven’t been able to determine the cause.
From the application logs, everything appears normal until the expected Page Render action, which never occurs in production (but does occur locally), so timeout finally. Below are the relevant log entries:
<code>2025-09-12 12:55:25.740-04:00 &#91;appdev&#93;&#91;D:2&#93;&#91;T:6&#93;&#91;DEBUG&#93; DNN.Trace - PortalModuleBase.OnLoad Start (TabId:156,ModuleId:596): ASP.desktopmodules_evotiva_dnnbackup_backupconfigurationoffsite_ascx 2025-09-12 12:55:25.740-04:00 &#91;appdev&#93;&#91;D:2&#93;&#91;T:22&#93;&#91;DEBUG&#93; DNN.Trace - PortalModuleBase.OnLoad Start (TabId:156,ModuleId:596): ASP.desktopmodules_evotiva_dnnbackup_backupconfigurationoffsite_ascx 2025-09-12 12:55:26.431-04:00 &#91;appdev&#93;&#91;D:2&#93;&#91;T:22&#93;&#91;DEBUG&#93; DNN.Trace - PortalModuleBase.OnLoad End (TabId:156,ModuleId:596): ASP.desktopmodules_evotiva_dnnbackup_backupconfigurationoffsite_ascx 2025-09-12 12:55:26.431-04:00 &#91;appdev&#93;&#91;D:2&#93;&#91;T:6&#93;&#91;DEBUG&#93; DNN.Trace - PortalModuleBase.OnLoad End (TabId:156,ModuleId:596): ASP.desktopmodules_evotiva_dnnbackup_backupconfigurationoffsite_ascx 2025-09-12 12:55:26.520-04:00 &#91;appdev&#93;&#91;D:2&#93;&#91;T:6&#93;&#91;DEBUG&#93; DNN.Trace - PageBase.Render Start (TabId:156,<a href="http://localhost:8080/Default.aspx?TabId=156&ctl=BackupConfigurationOffSite&mid=596&language=en-US)" target="_blank" rel="nofollow">http://localhost:8080/Def...=596&language=en-US)</a> </code>
In my local environment, I see the final PageBase.Render entry as expected, but in production it never appears, and the page eventually times out.
Has anyone experienced a similar issue, or can suggest potential causes and troubleshooting steps to identify why the render phase is not triggered in production?
Thank you in advance for any guidance.
Jie
I see it looks like it's doing a backup of the DB ? Sometimes low DB memory can cause timeouts, I would usually expect an error in the DNN "Admin Log".
Is your DB big?
At a guess (Assuming memory is the issue), you could try increasing the windows memory paging size. (https://learn.microsoft.c...on-to-the-page-file)
Also, check the windows event logs.
Joe, first thing. Always go to the vendor of the module causing the issue. In this case it’s Evotiva for their backup module. Historically, Evotiva has provided excellent support and can probably answer your questions. I have used Evotiva backup for years and it’s an outstanding product. In your particular case, the timeout in production rather than localhost and being on a configuration page leads me to guess is that the production server is behind a firewall that is blocking access to either an offsite storage site (like AWS) or perhaps Evotiva itself for a license check (the module does that but doesn’t do it for localhost IIRC).
Jie
Thank you David and @johnhenley for your helpful inputs—they’re much appreciated.
To clarify my situation: this issue only occurs when I try to open the Offsite link in the Evotiva Backup Configuration page. All other pages including other links in the same page work as expected. I did reach out to Evotiva support, but unfortunately they were unable to provide any guidance or suggestions.
Since the page request is processed within the DNN platform, I’m hoping the community might have additional insights.
So far, I have checked the Windows system event log, DNN admin/system logs, and the SQL Server logs, but I haven’t found any error messages or helpful clues.
Are there any other diagnostic steps or tools you would recommend to further narrow down the root cause? Any guidance would be greatly appreciated.
- what version of DNN?
- what version of Evotiva backup?
- did evotiva say why they couldn't assist you?
- had this previously been working?
- what offsite backup options are you using?
- for troubleshooting, I'd start with browser tools and capture what network calls are being made
Jie
Thank you all again for your valuable input.
After thorough investigation, no one was able to identify the exact cause of the issue, but we were able to find a workable solution.
We added the module to a new page and performed all actions from there, which resolved the problem, the issue is still there in the original page though.
Hopefully, this approach may help anyone encountering a similar issue.
Posted By Jie on 9/17/2025 6:34 AM
Thank you Jie for taking the time to share your solution!
