Create roles with custom RoleID
Hi everyone.
I need to create DNN roles with custom ids.
I see that the insertion in the "Roles" table is carried out by a store procedure which returns the value of the self-incrementing field which represents its key.
I don't want to modify the DB, I would like to do it in an "orthodox" way by writing a provider that allows all of this
[CODE]
SET IDENTITY_INSERT Roles] ON;
INSERT INTO Roles (...) Values(...);
SET IDENTITY_INSERT Roles] OFF;
[CODE]
but I have no idea how to override the default DNN provider.
Am I going the wrong way?
Has the same need happened to you?
Could you share your insights by providing examples?
S.
Even if this is an interesting question, I wonder why you would like to do this. An ID is just an ID and should never be interpretable in some way. So what is the reason and usecase to do this?
Legitimate question, but I avoided providing explanations in advance so as not to confuse ideas.
Standard roles are provided in our product, but customers can create their own. As well as other types of objects.
Roles are matched to the objects they can view.
But what happens when I update the product?
The new roles created as standard are installed, overwriting those created by the customer.
So if I have 20 roles as a standard (IDs from 1 to 20), the customer ones start at 21.
If at the next update I provide 5 more roles as standard (with related DNN site object enablements), 5 of the customer will be overwritten.
During the upgrade I could update the references of the custom roles, but in the DNN object collection it is difficult to distinguish between the standard role ID and the custom role ID.
Although this gets more into a "philosophical" discussion: in your concept is some meaning in the RoleID (RoleID <= 20 means Standard Role etc.). This is something I would avoid, because an ID is just an ID. Using the RoleName is much more the way to go, eg.
<code>UserInfo.IsInRole(string roleName)</code>
So you have to flag the "Standard" roles in some way, that they cannot get deleted or renamed by the customers, as some logic from your side relays on them. And there is something in DNN to reach this, and this is the <code>IsSystemRole</code> property of the RoleInfo object. Just set it to <code>true</code> when you create the role.
Hope that helps.
I fully agree with your observations.
But the DNN DB is structured in order to relate the PKs of the objects, as it should be.
In a purely functional context, there is no other way than to rely on the name of the role, which in fact establishes its purpose.
But if we go down one level, I have to consider that DNN objects are assigned visibility (or not) to the role with a certain ID, because in fact it is the data persisted in the database.
PS: the customer cannot modify anything of the standard, he can only add: roles, users, objects, etc...
S.
Honestly, I think this is indeed possible, but it would be pretty hacky and would require a custom <code>RoleProvider</code> is created to handle all of these things.  Though, even with all of this work, you'll have weird bugs that you'll just have to deal with.  This is because the rest of DNN uses IDs/PKs differently than your app intends to.
However, to avoid these kinds of "workarounds" in the past, we've simply implemented logic around the naming convention of Role Names, as Michael suggested.
Thanks Will,
if customer create custom roles, how can i know:
1) Their names?
2) What objects they enable?
3) Which users are assigned to?
From the database and its relationships.
Before each update I save the customer's custom data, but repopulate them in the db after the update (yes, in fact I'm going to replace it with that of the updated version...) at the moment it is only possible by going through the DNN API.
[CODE]
RoleController.Instance.AddRole
[CODE]
Which results in a new id being assigned to an old role that is already set to existing objects that I don't have direct control over.
So you're referring to implementing a RoleController instead of a RoleProvider?
Sorry for my noobish questions.
S.
Additional question: how to correctly load/inject a RoleController/RoleProvider instead of default one?
I'm working on DNN 7.4 (but I'm slowly migrating to 9.11.02 :-D)
S.
Posted By Seek on 8/10/2023 5:02 PM
Thanks Will,
1) Their names?
ad 1) and 3): There are three tables, Roles, Users and UserRoles. The names of the roles can be found in the Roles table ("RoleName"), and the users assigned are in the UserRoles table. Eg, to find all users in the Administrators role, you can use this statement in the SQL Console:
<code>SELECT<br />   r.RoleName,<br />   u.FirstName,<br />   u.LastName,<br />   u.Username,<br />   u.Email<br /> FROM<br />   dbo.Roles r<br />   INNER JOIN dbo.UserRoles ur ON ur.RoleID = r.RoleID<br />   INNER JOIN dbo.Users u ON u.UserID = ur.UserID<br /> WHERE<br />   r.PortalID = <em>your_portal_id</em> AND<br />   r.RoleName = 'Administrators'</code>
ad 2) I think the relevant tables are Permission, PortalPermission (PortalID from Partals), TabPermission (TabID from Tabs), FolderPermission (FolderID from Folders) and ModulePermission (ModuleID from Modules), maybe there are some more in your usecase (PersonaBarPermission, ContententWorkflowStatePermission, and others related to some third party modules like ActiveForums_Permissions etc.), but it's quite easy to explore.
Posted By Seek on 8/11/2023 9:35 AM
S.
The role provider is defined in the web(dot)config, the original entry is
<code>{roles defaultProvider="DNNRoleProvider"}<br />   {providers}<br />     {clear /}<br />     {add name="DNNRoleProvider" type="DotNetNuke.Security.Roles.DNNRoleProvider, DotNetNuke" providerPath="~\Providers\MembershipProviders\DNNMembershipProvider\" /}<br />   {/providers}<br /> {/roles}</code>
(use < and > instead of { and })
