DNN 360 CISS Menu
We recently upgraded a DNN website with the DNN360 CISS Navigation Suite to DNN 932
Vendor isn't available any more and now we get this error:
Method+not+found%3a+%27System.Collections.Hashtable+DotNetNuke.Common.Globals.get_HostSettings()
Looks like a problem with deprecated API in DNN
Does have an upgrade for this module / workaround / fix
Please help?
Is that the "CISS Side Menu"?
In your case, I would look at the HTML rendered by the CISS menu and duplicate it with a DDR Menu template. Same structure, classes, etc. and integrate that into your theme. You'll be future-proofed that way.
For the side menu, the basic Tokens menu with appropriate tab selectors probably will work for you. I have found that it's fairly easy to use DDR to replace lots of existing menus. Occasionally I'll need to take an existing template, make a copy, and add appropriate classes to match the menu I'm replacing.
I agree a custom DDR menu template is the best solution.
