Visual Basic
I'm trying to reuse an old DNN code written in VB but I receive this message:
DotNetNuke.Services.Exceptions.ModuleLoadException: 'Visual Basic' is not a supported language.
But in Extentions > Create new module
there is the possibility to select Visual Basic as language.
I really need to convert my module from VB to C#?
Yes, you can still use VB to write modules.
It has been a while, but I'd guess that there is some configuration item that is not set. Possibly something in web.config?
Are you doing this as a compiled module or an uncompiled one?
This is a good news!
My module is not compiled. I'm writing it into the editor. But which could be the problem in web.config? My module doesn't use any configuration.
For more infos, this is the complete error message:
Error: Famiglia is currently unavailable. DotNetNuke.Services.Exceptions.ModuleLoadException: 'Visual Basic' is not a supported language. ---> System.Web.HttpParseException: 'Visual Basic' is not a supported language. ---> System.Web.HttpParseException: 'Visual Basic' is not a supported language. ---> System.Web.HttpException: 'Visual Basic' is not a supported language. at System.Web.Configuration.CompilationSection.GetCompilerInfoFromLanguage(String language) at System.Web.UI.TemplateParser.ProcessLanguageAttribute(String language) at System.Web.UI.TemplateParser.ProcessMainDirectiveAttribute(String deviceName, String name, String value, IDictionary parseData) at System.Web.UI.TemplateControlParser.ProcessMainDirectiveAttribute(String deviceName, String name, String value, IDictionary parseData) at System.Web.UI.TemplateParser.ProcessMainDirective(IDictionary mainDirective) --- End of inner exception stack trace --- at System.Web.UI.TemplateParser.ProcessException(Exception ex) at System.Web.UI.TemplateParser.ParseStringInternal(String text, Encoding fileEncoding) at System.Web.UI.TemplateParser.ParseString(String text, VirtualPath virtualPath, Encoding fileEncoding) --- End of inner exception stack trace --- at System.Web.UI.TemplateParser.ParseString(String text, VirtualPath virtualPath, Encoding fileEncoding) at System.Web.UI.TemplateParser.ParseFile(String physicalPath, VirtualPath virtualPath) at System.Web.UI.TemplateParser.ParseInternal() at System.Web.UI.TemplateParser.Parse() at System.Web.Compilation.BaseTemplateBuildProvider.get_CodeCompilerType() at System.Web.Compilation.BuildProvider.GetCompilerTypeFromBuildProvider(BuildProvider buildProvider) at System.Web.Compilation.BuildProvidersCompiler.ProcessBuildProviders() at System.Web.Compilation.BuildProvidersCompiler.PerformBuild() at System.Web.Compilation.BuildManager.CompileWebFile(VirtualPath virtualPath) at System.Web.Compilation.BuildManager.GetVPathBuildResultInternal(VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile, Boolean throwIfNotFound, Boolean ensureIsUpToDate) at System.Web.Compilation.BuildManager.GetVPathBuildResultWithNoAssert(HttpContext context, VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile, Boolean throwIfNotFound, Boolean ensureIsUpToDate) at System.Web.UI.TemplateControl.LoadControl(VirtualPath virtualPath) at DotNetNuke.UI.ControlUtilities.LoadControl[T](TemplateControl containerControl, String ControlSrc) at DotNetNuke.UI.Modules.WebFormsModuleControlFactory.CreateControl(TemplateControl containerControl, String controlKey, String controlSrc) at DotNetNuke.UI.Modules.WebFormsModuleControlFactory.CreateModuleControl(TemplateControl containerControl, ModuleInfo moduleConfiguration) at DotNetNuke.ModulePipeline.ModuleControlPipeline.LoadModuleControl(TemplateControl containerControl, ModuleInfo moduleConfiguration) at DotNetNuke.UI.Modules.ModuleHost.LoadModuleControl() --- End of inner exception stack trace --
Probably I've found the problem:
when I create the new module (empty) DNN creates the ascx file with this in header:
Control Language="Visual Basic" ClassName....
But the string "Visual Basic" is not valid (I'm VB developer from long time).
So I changed it to "vb" and....now the error message does not appears any more.
This is wrong:
This is correct:
Control Language="vb" ClassName
Have a nice day!
Digging around in some old websites, I found a codedom section in web.config that has a compilers section.
Also, there is a codeSubDirectories section.
You may need one or both of these. But, as I said, it's been a long time since I've had to work in that arena. You may want to look for some old "how to build a DotNetNuke module" references using Google. Something before version 7 I think.
Hopefully, some folks here have longer memories than I do.
Don't worry!
I've solved as written above.
Thank you very much for your help.
Davide
