DNN 9.4.0 upgrade - IFrame failure
After upgrading to DNN 9.4.0 the latest IFrame  (8.1.1) module fails with the following error:
Error: UserReg - FIGU in a Nutshell is currently unavailable. DotNetNuke.Services.Exceptions.ModuleLoadException: Value cannot be null. Parameter name: source ---> System.ArgumentNullException: Value cannot be null. Parameter name: source at System.Linq.Enumerable.Count[TSource](IEnumerable`1 source) at DotNetNuke.Modules.IFrame.UI.IFrame.get_Source() at DotNetNuke.Modules.IFrame.UI.IFrame.Page_Load(Object sender, EventArgs e) --- End of inner exception stack trace ---
Was IFrame (8.1.1) tested with DNN 9.4.0? Any ideas on how to correct this error or where to start looking?
As I mentioned in my comment on the GitHub issues page, I could not reproduce this behaviour - the PDF file displays correctly in all browsers I tried on a desktop PC, and on mobile devices it requests the permission to download files, or displays a button to download the file.
I have not tested IFrame on DNN 9.4.0 yet, but it seems there are a some issues when upgrading to DNN 9.4.0 - it could have something to do with that.
Anyway, if you still have this issue let me know. I will provide an assembly with the debug information, then we could narrow down th error.
I had the same issue... I just ended up writing my own using 2SXC. It was too simple of a module to spend too much time on.
Fixed a bug with DNN.IFrame version 08.01.02 - please check if that is the one that helps. Please note that it needs .Net Framework 4.7.2 now, even if installed on DNN 8.0.0+.
Hello,
I have a live demo that you can test.
When you open the link in Edge -> Browser crashes. I can not even debug :-(
When i open this in Firefox -> load is normal and you see it in the DOM
URL: https://dnn.fonds209.be/nl-be/Statuten
embed height="650" internalinstanceid="49" src="https://www.fonds209.be/Portals/1/Downloads/statuten/BS_2812.pdf" width="100%"
strange behavior.
Nobels,
I see the PDF in Edge (but the Url is https://www.fonds209.be/nl-be/statuten.aspx)
In Firefox I only get a download link to the PDF.
Sorry have the wrong URL posted.
https://www.fondsmet.be/nl-be/Statuten
The problem is only in Edge browser
