DNN extension installer Cleanup component in manifest problem
I have been cleaning up some DNN modules lately for clients.
They contained JS and CSS files that are no longer in use, so I added a cleanup task to the module manifest and noticed something that's not in accordance with the documentation at https://www.dnnsoftware.c...ki/cleanup-component
But I could not get it to work for some reason although I had it workign before.
Spending a while debugging this so sharing my findings in case it saves someone else the headache.
The manifest syntax is straightforward:
But that linked documenation states the file can have any name, which I found out is not correct.
I tried naming it clean_04.09.00.txt but that did nothing.
It seems like you must use [Module version].txt
You should also note that the DNN installer will report success even when nothing is deleted
The install log will say "Component installed successfully - Cleanup" regardless, so don't rely on that to confirm it worked.
HTH
Timo, I had similar experience, but in my case, I wanted to move the cleanup files to a separate (/cleanup/) folder.  (see https://github.com/DNNCom...yForums/issues/1742) so they aren't crowding up the module's root folder. I was not successful in doing this either. I ended up giving up. Perhaps we should open some issues to see if this can be fixed/enhanced?
Yes, I tried putting it in a fodler too and as you said, that didn't work either.
I spoke to  @Peter Donker and he told me fixing this would not be an easy task..
