Edit Modules mode - when closed, can't view them, either invisible or the changes do not take place. Content panes.
I have a concerning problem with one of our DNN sites. It's using 10.2.3 but using from a vendor that cannot provide or fix the problem right now due to a certain war going on and having their telecommunications disrupted.
When I open and edit a module, whether it is html or a custom module (NewsArticles from Adv. News Articles), it is visible, but when I close the edit button, the content disappears!!! This has happened for at least a week. I have investigated caching, permissions and I am at a loss. It's like there is a bug with the content panes. I don't see anything happending in the developer tools.
http://journalbeta.nafo.int/Submit
I changed the position of panes on this webpage and it didn't switch.
JNAFS > Volumes > Articles : Page 1 of 43
Any help would be appreciated.
Thanks,
Alexis
alexismaria since the vendor can't help you out right now, maybe if you've a recent backup of the website, you can try to restore it in a different place than production and tried to replicate the problem, if the problem is not there, you can track down the source of the problem more easily (a DNN update, a module update, a recent change in the environment, etc.)
Hi Alexis,
Did you upgrade recently? And from what version? Becaus since DNN 10 there is also workflow. It might be that you can see the content in edit mode but for 'normal view' it still needs to be approved to be published.
cheers
I disabled the versioning and it showed up! Thank you.
I wouldn't have figured that would work and I am glad it is simple. As a user, it doesn't make sense, but I'll remember this for future use.
Great to read it worked out!
I think the feature could be a great enhancement, but:
  • The default is kind of a breaking change for editor workflows
  • It did not come with a manual so, it is a bit of reverse engineering how it was meant to work :-)
Have a great day!
