DNN Manifest
Dear all,
In the manifest file, there is a Cleanup component.
Can I use it to delete some old folders from a skin ?
Ex: Install new bootstrap 5 folder and delete the old bootstrap 3 one
Thanks for your help.
Yes you can.
[component type="Cleanup" version="06.06.01" glob="Portals/_default/Skins/MySkin/Bootstrap3/**/*.*;"]
 [/component]
 [component type="Cleanup" version="06.06.01"]
 [folder]
 [path]Portals/_default/Skins/MySkin/Bootstrap3[/path]
 [/folder]
 [/component]
(replaced <> with [] as it would not show up correctly..)
The first part removes the files, the second the folder.
docs.dnncommunity.org/content/tutor...index.html
