DNN Module Fails to Install After Adding .ascx View — "File Not Found" or Upload Zip Error
I'm developing a DNN module using Visual Studio 2022 (Community Edition). Everything works fine until I add a new .ascx view file to the project (e.g., Indicateurs1.ascx) and reference it in the .dnn manifest:
                DesktopModules/Indicateurs/Indicateurs.ascx
                True
                Indicateurs View
                View
                0
After doing this and building the project, the ZIP is generated as expected, but:
  • The module becomes impossible to upload via the DNN extension installer
However, I confirmed the file exists in the project, and its properties are set to:
  • Build Action: Content
  • Copy to Output Directory: Copy Always
🧪 What I’ve tried:
  • Verified file is in the ZIP
  • Checked .dnn file paths
  • Compared against working modules
  • Checked IIS permissions
  • Tried different controlKey values
  • Recreated the .ascx file from scratch
  • Verified Visual Studio workloads (ASP.NET Desktop, Web)
Why does adding a simple .ascx file manually break the module ZIP packaging — even if the file physically exists — and only works after enabling this specific workload? Is there an internal dependency on MSBuild items that Visual Studio adds only when the template is used?
Thanks for your help!
True
Indicateurs View
View
0
