DNN Search Function
when i click on the "see more results" on the dnn search bar, nothing happens and just shows href=javascript:void(0).
is there something i forgot to do?
Sounds like a skin issue. Did you try to set the page on Xcillion? Just tested in 9.7.0 and that works as expected.
Posted By Tycho de Waard (SU) on 22 Sep 2020 03:45 AM
I am currently using a custom skin on my system.
Is there anything that i can do to rectify the issue?
First test the search on a page that has Xcillion. If that works, you know for certain that it is a skin issue.
Second: check Chrome (inspect element) for errors to see what js is screwing things up.
Posted By Tycho de Waard (SU) on 22 Sep 2020 04:01 AM
I have tested the search on a page that has Xcillion but it shows the same results.
The console does not show any errors with the js though.
If you have a link you can email me ([email protected]) I can take a quick peak. Maybe worth a shot.
Posted By Tycho de Waard (SU) on 22 Sep 2020 04:42 AM
Thank you so much but unfortunately i do not have a link to the website. I am working on it on my local machine.
Will sharing a snippet of the js code help in any way?
Posted By andyy on 22 Sep 2020 02:27 AM
I saw you posted the same question in 3 sub-forums. Please do not do that, limit a question to a single thread. I removed the other 2 posts.
Posted By Timo Breumelhof on 22 Sep 2020 10:03 AM
ok
Likely the search results page is not defined under admin.
