Reinstall JWT after deleting
I was not able to get JWT to work so I deleted it thinking Im uninstalling it and now I don't see it in the available extensions. How can I install it again?
Yes, Just reinstall.
"Available Extensions" are those in the install/modules folder. They are deleted when they are installed.
I do not see it under Installed or Available Extensions.
You will need to download the module and install from Settings/Extensions/Install Extension.
You can find it inside of the Install package for DNN. Use the install package for the version that you are using. It is in the Install/Provider folder of the install zip file.
