DNN Survey Module question
Hi - I'm running DNN 9.1.1 and Survey 4.60.00
I need to upgrade DNN to version 9.3.2 (first to 9.2, and then to 9.3.2)
Should I upgrade the Survey module before upgrading DNN?
It looks like I need to be at DNN 9.02.02 before upgrading to Survey 9.00.01.
Can you advise the best order to do the upgrades of DNN and the Survey module?
Tom
I "think" that you upgrade the module(s) and then you upgrade DNN.
Hi Tom,
as mentioned in another thread, the easiest way would be to unzip the DNN upgrade package and then copy the Survey module install package to the /install/modules folder before starting the upgrade - the module will then upgrade during the upgrade process.
Anyway, it does not matter if you upgrade the module before or after upgrading DNN. The only thing that can happen is that you get errors on the pages with the module before you upgrade the module when you upgrade DNN first.
And never forget: Backup (files and database) before upgrading anything...
