Format HTML Visualizer for Reports Module
We are running the latest releae of the Reports Module on DNN 09.13.9 and are trying to make sense of the use of the HTML Visualiser.  I cannot locate a sample template that will run correctly.  I have a SQL query that suplys correct information using the Grid Visualizer;l but would like rto use the HTML Visualiser.
What is the complete format or can you provide a sample template.  The snippet in the current documentation leaves a lot to be desired.
Just for grins, here is a sample HTML Template that we are using:
<!-- DNN Reports Module HTML Template -->
<!-- Course Description C-010 -->
[Course_Number] - [Course_Title]
[Course_Description]
<!-- Replace Column1, Column2, etc., with your actual column names -->
<!-- Use [FieldName] to dynamically insert data from your SQL query -->
<!-- Example: Replace Field1, Field2, etc., with actual field names -->
Fee Supplies
$[Course_Fee] $[Course_Suggested_Supply_Fee]
Prerequisite: [Course_Prerequisite]
Course Notes: [Course_Note]
<!-- Optional CSS for styling -->
