Forms A List Module Sizing Text Field
https://support.vigilant1.com
  • v. 09.10.00 (0)
  • 4.8
GitHub - DNNCommunity/DNN.FormAndList: Design your own table complete with field types, validation and custom user permissions.
Hello Team,
working with the FormsAndList module and cant seams to figure out how make the "How can we help" text box field on my site larger. Didnt really care for the full html field it was a bit to much. Open to another cheap forms module if someone has some suggestions. Only other things was I couldnt add a ? in the title fields and a few others when configuring. Not sure how to remove the cancel button.
Thanks,
Hi Joseph,
First: What/how would you like to have the text box larger? As in wider? Or higher? The width has a max because the page (or at least that section) is split in 2 columns. So, this is as wide as you can go. If you want more rows, you can use the text area. If this open source module is not for you, you can take a look at Openform: http://www.openextensions...open-source/openform Sascha also created OpenContent which is a structured content solution.
If you want to go with something commercial: Live Forms and ActionForm are the 2 best extensions around and play nicely with the other extensions of the respective vendors.
Outside the box: most helpdesksystems or business applications like Flowlu or Plutio have their own forms that you can embed.
Awesome, thanks man for the help! Just wanted the field height increased but it seams to share the same style. I'll check out what you sent over now.
Thanks Again,
Joe
