Forum Error When Posting HTML & Issue with Friendly URLs
Hey everyone,
Hope you’re all doing well!
Just wanted to share an issue we’re running into — whenever we post HTML content in the community forum \ active forum, I get this error message:
<code>Error: AZ Managed IT Forum is currently unavailable. DotNetNuke.Services.Exceptions.ModuleLoadException: Input string was not in a correct format. -&#45;&#45;&gt; System.FormatException: Input string was not in a correct format. at System.Text.StringBuilder.FormatError() at System.Text.StringBuilder.AppendFormatHelper(IFormatProvider provider, String format, ParamsArray args) at System.String.FormatHelper(IFormatProvider provider, String format, ParamsArray args) at DotNetNuke.Services.Tokens.PropertyAccess.FormatString(String value, String format) at DotNetNuke.Modules.ActiveForums.Entities.TopicInfo.GetProperty(String propertyName, String format, CultureInfo formatProvider, UserInfo accessingUser, Scope accessLevel, Boolean& propertyNotFound) at DotNetNuke.Services.Tokens.BaseCustomTokenReplace.replacedTokenValue(String objectName, String propertyName, String format) at DotNetNuke.Services.Tokens.BaseTokenReplace.ReplaceTokens(String sourceText) at DotNetNuke.Modules.ActiveForums.Services.Tokens.TokenReplacer.ReplaceTopicTokens(StringBuilder template, TopicInfo topic, PortalSettings portalSettings, SettingsInfo mainSettings, INavigationManager navigationManager, ForumUserInfo forumUser, Uri requestUri, String rawUrl) at DotNetNuke.Modules.ActiveForums.Controls.TopicsView.ParseTopics(String Template, DataTable Topics, String Section) at DotNetNuke.Modules.ActiveForums.Controls.TopicsView.BindTopics(String topicsTemplate) at DotNetNuke.Modules.ActiveForums.Controls.TopicsView.OnLoad(EventArgs e) --- End of inner exception stack trace --- </code>
It only happens when HTML is included in a post — plain text works fine.
Just wanted to see if anyone else has run into this or found a workaround.
Friendly URL Issue
When we enable Friendly URLs, the forum becomes inaccessible from the root page — clicking the forum link just doesn’t load anything.
Just wanted to put this out there and see if anyone else has run into these issues or has a workaround.
Thanks in advance for any help!
What version of the forums module? This was an issue that was addressed in 9.1
https://github.com/DNNCom...tyForums/issues/1576
So if you’re on an earlier version, please test latest https://github.com/DNNCom...unityForums/releases
Regarding friendly URLs, what is the page/url on which the forums module is placed? Is it on a top-level page or on a subpage (like /community/forums/)?
Hi John good morning man. I have it here https://azmanagedit.com/community-forums your right I'm on 9.0.0 thanks will do the upgrade!
No issues with the upgraded everything went good
Was trying to do some html in here
But it kind of strips everything
Then it looks wierd here
after enabling friendly URL
when I click a forum
the url changes and I cant view the topics.
https://azmanagedit.com/c...s/managed%20services
I can still access the other way
https://azmanagedit.com/community-forums/aff/9
Are you trying to insert html to display as an example to read the html or to actually render?
For display, make sure you wrap in “code” tags
thanks everythings working great I didnt have to change anything.
Hey john how are you using the code tags exactly? Is it built into the html editor?
Posted By D0rk52 on 10/13/2025 2:35 PM
I put together some documentation in the forums module wiki to explain how HTML / XML can be entered in different ways to render as content vs markup/documentation. Let me know if this helps...
https://github.com/DNNCom...-To-Enter-XML-&-HTML
