How do I add fonts to CKEditor?
Hello all, I hope this is the right place to post this question.
We have a project that requires 2 custom fonts to be added drop down selector within CKEditor. One of these fonts, Rubik is available on https://fonts.google.com/ the other has to be installed and added from the local server.
I have found how to do this using a simple vanilla build of CKEditor outside of DNN but the method does not work for the DNNConnect CKEditor provider build. I have read the blog posts by Steve Krantzman from last month and as I understand it the build used in DNN has been modified and uses a DB table for settings.
We have attempted multiple methods of trying to add the fonts to the CKEditor config with no luck. Can anyone share the proper procedure to add both fonts hosted on Google as well as using locally installed fonts? We are running on a fresh install of DNN v9.7.
Thanks in advance!
You can change the default font in contents.css. You can also change them in the Font combo as explained https://ckeditor.com/docs....html#cfg-font_names
If you want to add a custom font, it might be a bit harder, but it's doable. Check this: https://stackoverflow.com...ont-face-to-ckeditor
@AustinGuy We have come across & attempted both of these threads.
The first link you provide allows us to add the font names only, if you select the font from the drop down it is not applied properly and displays it as the default font.
The second link refers to editing the config.js file which changes do not appear to have any effect on the DNN CKEditor Provider version. We believe this is due to it is storing config settings in the DB table instead.
We have tested using the file located here: C:\DOMAINNAME\httpdocs\Providers\HtmlEditorProviders\DNNConnect.CKE\js\ckeditor\4.5.3, is that the correct location? To verify we also tried editing the config.js to simply set the background color of the editor which had no effect. Setting the the background color via the config settings in the HTML Editor Manager saved the setting in the DB table only, NOT in the config.js file.
Hoping someone has done this 1st hand and can provide details.
Posted By KHalladay on 20 Jan 2021 10:16 AM
Adding the font name to the Editor is not enough. For a custom font to show on the page, you also need to load the source for that font.
This means that you will have to add the link to the google fonts resource to you theme or the browser will never be able to load the font and will fallbck to the default font. If you already did that check what kind of HTML the editor is creating when you apply a custom font as there might be a font naming mismatch between the css and html.
Yes this method does display the font properly on the page itself but not within the editor,
That will be confusing for the end users. Where do I add the Google fonts info so that it applies within the editor?
How would it be specified if the font is local?
