Can't Upload Images - HTTP 405 Error
I am evaluating active forums 6.5 on dnn 9.8.1. as a test, i tried to post a message with an image attachment. the program reports that the image type is not allowed, but it is allowed on my site (jpg). so i tried the easydnn forums module but it reports http 405. its support agent says that it is permissions but he is off the mark because the apppool identity has full control to the root of the web folder (and below).
i am able to upload images in my theme manager, the html module, and the site and global resources modules. so i think that this issue might be ckeditor related - but not sure. i tried looking at some of its settings, but it is not clear what to change - if even that is the culprit.
i do have content security policy policies, but removing them did not help.
mea culpa on the active forums issue. it has its own list of allowed files and does not include jpg by default. adding it allowed the file to upload. unfortunately, viewing the uploaded image causes a nasty runtime sql error. i will open a new posting on it, but for those who must look at a bad accident:
AbsoluteURL:/DesktopModules/ActiveForums/viewer.aspx
ExceptionGUID:810ad2c6-d9bf-41c2-8afc-5900d4c2d80a
AssemblyVersion:9.8.1
PortalId:0
UserId:1
TabId:22
RawUrl:/DesktopModules/ActiveForums/viewer.aspx?portalid=0&moduleid=409&attachmentid=1
Referrer:https://www.etiquemarket.com/forums/aft/1
UserAgent:Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/87.0.4280.141 Safari/537.36
ExceptionHash:/VFfOZMMg9MveQQqJsZTO0DUn/8=
Message:Invalid object name 'dbo.vw_activeforums_TopicView as tv on tv.ContentId = A.ContentId INNER JOIN dbo.[activeforums_ForumTopics'.
StackTrace:
InnerMessage:Invalid object name 'dbo.vw_activeforums_TopicView as tv on tv.ContentId = A.ContentId INNER JOIN dbo.[activeforums_ForumTopics'.
InnerStackTrace:
at System.Data.SqlClient.SqlDataReader.TryConsumeMetaData()
at System.Data.SqlClient.SqlDataReader.get_MetaData()
at System.Data.SqlClient.SqlCommand.FinishExecuteReader(SqlDataReader ds, RunBehavior runBehavior, String resetOptionsString, Boolean isInternal, Boolean forDescribeParameterEncryption, Boolean shouldCacheForAlwaysEncrypted)
at System.Data.SqlClient.SqlCommand.RunExecuteReaderTds(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, Boolean async, Int32 timeout, Task& task, Boolean asyncWrite, Boolean inRetry, SqlDataReader ds, Boolean describeParameterEncryptionRequest)
at System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method, TaskCompletionSource`1 completion, Int32 timeout, Task& task, Boolean& usedCache, Boolean asyncWrite, Boolean inRetry)
at System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method)
at System.Data.SqlClient.SqlCommand.ExecuteReader(CommandBehavior behavior, String method)
at System.Data.SqlClient.SqlCommand.ExecuteReader(CommandBehavior behavior)
at Microsoft.ApplicationBlocks.Data.SqlHelper.ExecuteReader(SqlConnection connection, SqlTransaction transaction, CommandType commandType, String commandText, SqlParameter[] commandParameters, SqlConnectionOwnership connectionOwnership)
at Microsoft.ApplicationBlocks.Data.SqlHelper.ExecuteReader(String connectionString, CommandType commandType, String commandText, SqlParameter[] commandParameters)
at Microsoft.ApplicationBlocks.Data.SqlHelper.ExecuteReader(String connectionString, String spName, Object[] parameterValues)
at DotNetNuke.Modules.ActiveForums.Data.AttachController.Get(Int32 attachmentId, Int32 fileId, Boolean withSecurity)
at DotNetNuke.Modules.ActiveForums.af_viewer.OnLoad(EventArgs e)
Source:
FileName:
FileLineNumber:0
FileColumnNumber:0
Method:
I think it's better is you log this on github https://github.com/DNNCom.../Dnn.CommunityForums :-)
