Links module - which version to use with DNN 9.9.1?
 5 Subscribed to this topic
Page 2 of 2 << < 12
Hi Sebastian - I'm not sure I know exactly what you're asking. How do I re-save permissions. Is that something that should normally be done with a DNN upgrade?
I do notice that there are some differences in the folder permissions between my backup site (which was not upgraded, and the Links module still works correctly) and the upgraded site, which shows the problem. Does the upgrade to DNN 9.9.1 change the folder permissions?
I am not seeing any other permissions issues on the upgraded site, only in the Links module.
Tom, did you get your Links module working again and able to see files? What worked? I'm having the same issue. Thanks!
Page 2 of 2 << < 12
