mandeeps live token using with dnn sharp grid
I am attempting to use live token with dnn sharp grid
i am able to generate a token for as follows -  9/11/2024 12:00:00 AM
when trying to pass the date to a sql query see below i am getting a message that it cannot convert nvarchar to a date
when i test with Sql mangement studio and pass the exact token it works, I am thinking that dnn Sharp cannot recognize the token altough mandeeps stated that their token can be used with other modules
exec [dbo].[usp_ScoringDetailLiveTokens]
--@eventdate = '08-07-2024'
@eventdate = '{bob:CurrentEventDate.EventDate}'
has anyone used live tokens with dnn Sharp Grid
Also is ther another company that has a module that can generate tokens from a sql database query that can be used with dnn Sharp grid
Bob
Not sure if Mandeeps means that Live Tokens can be used by other Mandeeps modules or DNN Core modules or other modules in general. For that, I'd create a support ticket at Mandeeps.
AFAIK, modules creating their own tokens consider their own environment as a reference. So, 2SXC tokens work in 2SXC and Easy DNN tokens work in Easy DNN News.EasyDNN Gallery etc.
DNN Sharp Grid is part of the low code suite Plant an App. And Plant an App has its own Token module, called My Tokens.
regards
Tycho
