Page Load Exceptions
So these errors happen about 50% of the time (only to the custom modules) and its been happening for a few days now out of nowhere, and it makes working on the site extremly difficult. On top of that i have to deal with a very old version of DNN (For some reason i was told updating breaks things which is why we been stuck on version 3 of DNN for so long)
I'll take any advice anyone can throw at me, I'm at a loss for where to even begin.
Here are the error logs:
AssemblyVersion: 03.02.00
Method: CCC.DNN.Modules.CM_Application_Centre_View.CM_Application_Centre_View.Page_Load
FileName:
FileLineNumber: 0
FileColumnNumber: 0
PortalID: 0
PortalName: The CCC
UserID: 19766
UserName: 1064799
ActiveTabID: 116
ActiveTabName: Application Centre
AbsoluteURL: /en/Default.aspx
AbsoluteURLReferrer: https://test.ca/en/Defaul...id=116&Type=OpenApps
ExceptionGUID: 6f3529b3-77a8-4d2d-83c2-e09c182d7dc9
DefaultDataProvider: DotNetNuke.Data.SqlDataProvider, DotNetNuke.SqlDataProvider
InnerException: Internal Server Error
Message: DotNetNuke.Services.Exceptions.PageLoadException: Internal Server Error ---> System.Web.HttpException: Internal Server Error at CCC.DNN.Modules.CM_Application_Centre_View.CM_Application_Centre_View.Page_Load(Object sender, EventArgs e) at System.Web.UI.Control.OnLoad(EventArgs e) at System.Web.UI.Control.LoadRecursive() at System.Web.UI.Control.LoadRecursive() at System.Web.UI.Control.LoadRecursive() at System.Web.UI.Control.LoadRecursive() at System.Web.UI.Control.LoadRecursive() at System.Web.UI.Control.LoadRecursive() at System.Web.UI.Control.LoadRecursive() at System.Web.UI.Control.LoadRecursive() at System.Web.UI.Control.LoadRecursive() at System.Web.UI.Control.LoadRecursive() at System.Web.UI.Control.LoadRecursive() at System.Web.UI.Control.LoadRecursive() at System.Web.UI.Page.ProcessRequestMain() --- End of inner exception stack trace ---
StackTrace:
Source:
Server Name: CCC
Ugh... You're in a pickle!  (As "they" say in certain places.)  :)
The most obvious thing that would normally need to be done is to upgrade to the latest release.  With this being a version 3.xx instance, upgrading would be just as time-consuming as rebuilding the website.  Unfortunately, no matter the software, if it just sits there without regular maintenance (e.g., upgrades and updates), it will indeed break over time.  Seemingly (and sadly), it will indeed come out of nowhere as well.
What's most likely in your case is that a Windows Update is causing the code to break.  This is not something that would allow you to apply a quick fix.
If you have the expertise to rebuild the website in a current release of DNN, this would be your best and cheapest option to fix this now, as well and protect your website investment over the long term.  This is because much of the DNN work is already done.  It's a matter of finding feature parity with today's features and extension options.
If you don't have the resources to do this yourself, you can find an agency to help you as well.  :)
Did you check if the database or db logs aren't very large? That often causes issues like this.
Posted By Timo Breumelhof on 10 Jul 2019 04:37 AM
No large database logs and windows updates are deactivated.
Posted By jeff2 on 10 Jul 2019 02:23 PM
Eh.. really? Completely? In that case, are you sure the site has not been hacked?
Another thing you can do is create a new website with a new app pool identity and move the whole site to that new website.
Next thing I would do is move the site to your local machine and see if you get the same error.
Do you have the source of these modules?
Can we have a look at the site to see how complex it is?
Posted By Timo Breumelhof on 10 Jul 2019 02:53 PM
It dosent look like any signs of that.
Posted By Timo Breumelhof on 10 Jul 2019 02:56 PM
The source of the modules have been long lost. Where only a few months away from migrating to a new website.
I'd agree with the others... The next step is to see if you can run the website locally to see what happens.
If you need the source of those custom modules, it can be regenerated, but such a thing is time-consuming. We've had to do that many times for clients we inherited.
Regardless, this may be a reason to place a higher priority on migrating the website, I think. :(
