Resource Manager 9.13.3 a couple of questions / issues
Hi, I'm testing the new Resource Manager (v9.13.3) , overall it looks great.
One issue I noticed is that when you right-click on a second-level folder in the left pane, the popup toolbar that appears gets cut off/truncated depending on the width/height of the folder name and if it's near the obttom of the folder level. Here's a link to a screenshot showing the issue:
https://santacruzcountyca.gov/resourcemanager-menu.png
I've tried all my css tricks to fix this (z-index, etc) to no avail. In the right pane, the pop-up looks fine.
I also notice that the Resource Manager seems to be slower in Microsoft Edge as compared to Firefox. I notice this when opening a folder, it takes 3 seconds to respond in Edge, and responds immediately in Firefox.
I also wanted to ask whether there are newer versions of the Resource Manager that can be used with DNN 9.13.3.
Let me know if you know about any of these issues, and also please let me know if I should be asking this question somewhere else.
Tom
Tom, if you find a bug you should report this using GitHub https://github.com/DNNCommunity
The Resource Manager it's part of the DNN install file, if you've the latest DNN version installed you must have the latest version of the Resource Manager as well.
Check out this link to make sure you're on the latest version of DNN https://github.com/dnnsof...nn.Platform/releases
Regards.
Does the design quirk happen with the default theme as well?
Hi - I have submitted this issue on github:
https://github.com/dnnsof...Platform/issues/6112
I tried different themes and the popup problem seems to happen on all of them.
Thanks!
Tom
Thank you for taking the time to logging the issue :-)
