SQL Exception in Active Forums – Invalid Length Parameter in LEFT or SUBSTRING Function
Hi all,
We’re running into a recurring SQL exception within the Active Forums module on DNN 10. Here's the core error message from the logs:
Invalid length parameter passed to the LEFT or SUBSTRING function.
For now, we've documented it and are investigating further. If anyone has patched this or can point to an updated stored procedure or module release that addresses this, we’d appreciate the help!
Thanks,
—Joseph
https://azmanagedit.com
This is fixed in upcoming 9.0 forums release. https://github.com/DNNCom...nityForums/pull/1464
If you want to manually fix it, you can take the sql from that PR.
