Template Creation Error
I have been trying to access the latest version of the Eraware Dnn SPA EF CI Stencil Module Template and have installed Node.js development while runnning Visual Studio 2022 on .NET Framework 4.8.1 but keep running into this load component assembly error. I do not know how to remedy this error and would appreciate any help, documantation, or links to helpful videos explaining any additional extensions needed or what the problem potentially is. I attached an image of the error code and the module template download for reference. Thank you.
Daniel Valadas fixed this error and it will be implemented in Eraware v.1.11.0
I will probably be working on the template during today's co-coding session in Discord and if everything goes good, I'll publish that update today to the marketplace.
