Upgrading Blog Module
I have an site that is using Blog 3.5.1 on DNN 8.0.4 (upgraded from an equally old DNN version)
So ... how to I upgrade
  1. to a modern version of the Blog Module
  2. and to a version that runs on DNN 9.3.2
Somewhere in there, I think, the blog module changed considerably ...
Any suggestions, tips, etc. would be appreciated greatly.
I upgraded 3.5.1 to 4.0.0
When I try to upgrade to 4.0.1 I get this error:
Start Sql execution: 04.01.00.SqlDataProvider file
Warning SQL Execution resulted in following Exceptions: System.Data.SqlClient.SqlException (0x80131904): The object 'DF_Blog_Blogs_EnableTwitterIntegration' is dependent on column 'EnableTwitterIntegration'. ALTER TABLE DROP COLUMN EnableTwitterIntegration failed because one or more objects access this column. at System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection, Action`1 wrapCloseInAction) at System.Data.SqlClient.SqlInternalConnection.OnError(SqlException exception, Boolean breakConnection, Action`1 wrapCloseInAction) at System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj, Boolean callerHasConnectionLock, Boolean asyncClose) at System.Data.SqlClient.TdsParser.TryRun(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj, Boolean& dataReady) at System.Data.SqlClient.SqlCommand.RunExecuteNonQueryTds(String methodName, Boolean async, Int32 timeout, Boolean asyncWrite) at System.Data.SqlClient.SqlCommand.InternalExecuteNonQuery(TaskCompletionSource`1 completion, String methodName, Boolean sendToPipe, Int32 timeout, Boolean& usedCache, Boolean asyncWrite, Boolean inRetry) at System.Data.SqlClient.SqlCommand.ExecuteNonQuery() at DotNetNuke.Data.SqlDataProvider.ExecuteScriptInternal(String connectionString, String script) ClientConnectionId:116ca303-237a-491d-bba1-717c663609e0 Error Number:5074,State:1,Class:16 ALTER TABLE dbo.Blog_Blogs DROP COLUMN [EnableTwitterIntegration]
Info End Sql execution: 04.01.00.SqlDataProvider file
Any suggestions?
Hmmm...
I was able to execute that sql file using SSMS and the Blog seems to be working.
So, after getting to 4.1.1 and the Blog Module seemingly working ... I tried a quick jump to 6.4.1. This resulted in another error:
Error: NPI Web Library is currently unavailable. DotNetNuke.Services.Exceptions.ModuleLoadException: Unknown server tag 'dnnweb:DnnCodeBlock'. ---> System.Web.HttpParseException: Unknown server tag 'dnnweb:DnnCodeBlock'. ---> System.Web.HttpParseException: Unknown server tag 'dnnweb:DnnCodeBlock'. ---> System.Web.HttpException: Unknown server tag 'dnnweb:DnnCodeBlock'. at System.Web.UI.TagPrefixTagNameToTypeMapper.System.Web.UI.ITagNameToTypeMapper.GetControlType(String tagName, IDictionary attribs) at System.Web.UI.MainTagNameToTypeMapper.GetControlType2(String tagName, IDictionary attribs, Boolean fAllowHtmlTags) at System.Web.UI.MainTagNameToTypeMapper.GetControlType(String tagName, IDictionary attribs, Boolean fAllowHtmlTags) at System.Web.UI.RootBuilder.GetChildControlType(String tagName, IDictionary attribs) at System.Web.UI.ControlBuilder.CreateChildBuilder(String filter, String tagName, IDictionary attribs, TemplateParser parser, ControlBuilder parentBuilder, String id, Int32 line, VirtualPath virtualPath, Type& childType, Boolean defaultProperty) at System.Web.UI.TemplateParser.ProcessBeginTag(Match match, String inputText) at System.Web.UI.TemplateParser.ParseStringInternal(String text, Encoding fileEncoding) --- End of inner exception stack trace --- at System.Web.UI.TemplateParser.ProcessException(Exception ex) at System.Web.UI.TemplateParser.ParseStringInternal(String text, Encoding fileEncoding) at System.Web.UI.TemplateParser.ParseString(String text, VirtualPath virtualPath, Encoding fileEncoding) --- End of inner exception stack trace --- at System.Web.UI.TemplateParser.ParseString(String text, VirtualPath virtualPath, Encoding fileEncoding) at System.Web.UI.TemplateParser.ParseFile(String physicalPath, VirtualPath virtualPath) at System.Web.UI.TemplateParser.ParseInternal() at System.Web.UI.TemplateParser.Parse() at System.Web.Compilation.BaseTemplateBuildProvider.get_CodeCompilerType() at System.Web.Compilation.BuildProvider.GetCompilerTypeFromBuildProvider(BuildProvider buildProvider) at System.Web.Compilation.BuildProvidersCompiler.ProcessBuildProviders() at System.Web.Compilation.BuildProvidersCompiler.PerformBuild() at System.Web.Compilation.BuildManager.CompileWebFile(VirtualPath virtualPath) at System.Web.Compilation.BuildManager.GetVPathBuildResultInternal(VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile, Boolean throwIfNotFound, Boolean ensureIsUpToDate) at System.Web.Compilation.BuildManager.GetVPathBuildResultWithNoAssert(HttpContext context, VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile, Boolean throwIfNotFound, Boolean ensureIsUpToDate) at System.Web.UI.TemplateControl.LoadControl(VirtualPath virtualPath) at DotNetNuke.UI.ControlUtilities.LoadControl[T](TemplateControl containerControl, String ControlSrc) at DotNetNuke.UI.Modules.WebFormsModuleControlFactory.CreateModuleControl(TemplateControl containerControl, ModuleInfo moduleConfiguration) at DotNetNuke.UI.Modules.ModuleControlFactory.LoadModuleControl(TemplateControl containerControl, ModuleInfo moduleConfiguration) at DotNetNuke.UI.Modules.ModuleHost.LoadModuleControl() --- End of inner exception stack trace ---
Now, some google reveals that this is related to Telerik.
Suggestions about this one are welcome.
It's DNN 8.0.4 ...
The Telerik dlls in /bin are
Telerik.Web.Ui.dll no version in properties, but it is 18.5 mb in size
Telerik.Web.UI.Skins.dll Product version: 2013.2.717.40
DotNetNuke.Html.Editor.TelerikEditorProvider.dll    Product version:5.6.3.
I poked around a bit more and this starts happening after going from Blog 4.1.1 to Blog 5.0.0
As far as I can remember the blog module latest release 6.4.1 is compatible from Dnn 8.0 up to the latest Dnn version. Have you tried upgrading the blog module directly to 6.4.1 while staying in Dnn 8 ? Also is the server using SQL Server 2008 at least ?
FYI - I just ran the blog module through EVS and came up with the following compatibility table.  :)
(By the way, this is the route I'd suggest trying to upgrade as well... but it's sometimes different from site to site)
Blog Module Version Minimum Compatible DNN Version Installs w/ Out Errors Azure Compatible
04.00.00 04.06.02 No No
04.01.01 04.06.02 No No
05.00.00 06.02.00 Yes Yes
06.00.00 07.00.04 Yes Yes
06.00.11 07.00.04 Yes Yes
06.01.00 07.00.04 Yes Yes
06.02.00 07.02.00 No Yes
06.03.00 08.00.00 Yes Yes
06.04.01 08.00.00 Yes Yes
This, of course, doesn't take into account custom configurations and conflicts with other extensions.  I hope this helps (everyone).  :)
