Malformed Resource Files: #
 25 Subscribed to this forum
  • v. 09.13.04 (0)
  • 4.8
Errors reported in PB>Site Settings>Languages>Verify Language Resource Files
Malformed Resource Files: 146
Error Logging report (Typical)
[WARN] DotNetNuke.Services.Localization.LocalizationProvider - Missing localization key. key:ControlTitle_.Text resFileRoot:/DesktopModules/Hotcakes/Checkout/App_LocalResources/CheckoutView threadCulture:en-US userlan:
Possible cause/solution/problems due to errors?
GP
I've seen this before and once traced it to the "xsd:schema" section. If the namespace uses https, it throws this warning.
WARNING: https://www.w3.org/2001/XMLSchema
OK: http://www.w3.org/2001/XMLSchema
I decided to ignore the warning because in my mind it should be "https://..." and I have never noticed the resx not working becuase of this warning.
I don't know your specific warning, it's reporting HotCakes, but I don't think it's a HotCakes issue. I'm the OpenStore guy but Will Stroll (the HotCakes guy) usually checks into the forum, he may be able to clarify.
David,
this is not a Url, but a namespace URI (see here). The namespace is defined in the specifications at http://www.w3.org/2001/XMLSchema, and you can't change it. This is the reason of the warning. Anyway, no-one ever fetches anything at that location.
@Michael, Thx for the feedback, yes you're right.
Also found this....
https://github.com/dnnsof...Platform/issues/6053
Is the file in question encoded correctly? I used to see similar odd errors in the past when I used to create SqlDataProvider files using Notepad. The default file encoding would cause odd errors. If this is a concern, try opening the RESX file(s) in question in your favorite text editor. If the encoding says something other than UTF-8, then you may want to re-save it as UTF-8.
