Module Message Control
Hello ,
I have a problem where my skin has a dnn pane in the header, and DNN will display the verification message there after a user registers.
I do not want the module message to display there - any way to stop it, or direct it to another pane?
System messages are displayed by default n top of the pane "ContentPane" (each skin needs to have exact one pane with this name. you may easily rename your panes to assign this name to another pane you like to use.
Thank you for the response Sebastian.  My header has a pane named topbarpane - this is where the verification message is getting displayed.  So should I rename it?  Even though it is not called contentpane?
that's very strange, I am sure, any message should be displayed either inside a module or on top of pane "ContentPane".
Did you check source code of the rendered page using developer tools of your browser?
Thanks again for your quick response.
I checked the name of pane with visual studio - I am the developer.
I am running dnn 9.7.2 - not sure if that matters - but it might.
AFAIK, there hasn't been changes in this area recently, i.e. behaviour of your version should not differ from current one.
pleae check source code of the RENDERED page, where the message is injected - it might just be outside a module div and therefore been displayed on the wrong page position.
I looked at the code in dev tools on chrome - it is definatly imjecting into topbarpane.
It pushes my html to bottom.  I tryed posting code but it doesnt read and gets striped.  Trying taking out brackets.
It says it is : div id="dnn_ctr2669_ctl00_dnnSkinMessage" class="dnnFormMessage dnnFormWarning"
                            span id="dnn_ctr2669_ctl00_lblMessage"You are using an unverified account. Please verify your account by clicking on the link contained in the verification email that has been sent to you. Click a href="#" class="send-verification-mail">here/a to re-send the verification mail./span
                        /div
John,
question is: where is the div id="dnn_ctr2669_ctl00_dnnSkinMessage" injected - in which pane?
@Joe; sorry, but your reply is out of context and not helpful for the problem discussed.
Inside the topbarpane.
very strange, is topbarpane the first pane in the page code?
