Upgrade error 911 --> 920 code blocks (i.e. ).
Hello,
I upgraded from 9.1.1. to 9.2.0. and get this error
The Controls collection cannot be modified because the control contains code blocks (i.e. <% ... %>).
Is this a bug in DNN 9.2.0. or do I have to change the themes and remove all code blocks <% ... %> (actually not an option)
Is it fixed in version 9.4, 9.5 or 9.6
Didn't you modify anything? Because there is something old on https://www.dnnsoftware.c...e/posts/threadpage/3
No we didn't change the skin/container it's a DNNGo Theme
It did run perfect on DNN 9.1.1.
In that case, I'd send an email to Linda ([email protected]). Usually answers within a day.
Thanks Tycho!
I did send an email to Linda... I think they are asleep in Wuhan now... just wait...
But this i quite a breaking change in DNN 9.2... maybe migrate to custom theme is the way to go...
Posted By Willem on 15 Jul 2020 10:58 AM
Thanks Tycho!
Normally a skin does not break in 9.2.2 this must be something DNN Go specific. (they hack around in DNN a lot ;-))
There are pros and cons for both approaches. Custom gives you full control. But you're also the one investigating issues, fixing things, inventing wheels etc. If a skin needs a lot of custom work and / or evolves quite a bit, you want control, you want custom. Or if you have speed as a priority. Or if you think it is fun/art, because it is.
If you have to allocate the budget to functionality or if you don't have the css skills yourselvces, you might consider a commercial skin. Before dismissing this: it does score high on google page speed nowadays, you can adjust the css (there is even a contextual interface for that. No, not portal.css), there is google fonts, there is image compression, a visual content builder, save your own content types, etc etc.
on https://www.youtube.com/w...h?v=R4BWRAhEMIk&t=2s I did a quick tour. Does not include contextual css editing but that's great too.
