An unhandled error in dnn.jquery.js
Hi all!
After an upgrade from 9.0 to 9.13, I see the following unhandled error in JavaScript.
What could it possibly be?
What functionalities are affected?
Best regards and happy coding,
Roman
Did you upgrade following the suggested Upgrade path?
Is the error thrown from DNN itself or an extension (skin/module/...)
I'm guessing that at least one of the steps you took in the upgrade didn't fully extract and overwrite all of the dependency files.  Also, a common cause of this is due to not unblocking the zip files (upgrade packages).  Did you unblock each of them after downloading (and before using)?  Here's a quick tutorial on how to do that.
https://hotcakescommerce....block-File-Downloads
Hi Michael,
Thank you for your attention.
1. No. I think it was DNN_Platform_9.2.2.178_Upgrade.zip, DNN_Platform_9.8.0_Upgrade.zip, DNN_Platform_9.13.0_Upgrade.zip.
The upgrade was done by true experts. They professionally develop modules for the DNN Store.  I trust them 100%.
2. I don't know. The exception is thrown by dnn.jquery.js which is called before sys.WebForms is referenced (it must be somewhere in the MS Ajax library). Later on the page, sys.WebForms is referenced again without any problems, so the library is included at that time.
The error starts to appear during login and is thrown ever after. The error is not observed without login. sys.WebForms is used on each page of DNN.
My point was:
Has anyone here observed this error in 9.13? I thought it was common for the Upgrade to 9.13.
Cheers!
Roman
Thanks, Will for your suggestion,
I read the article. It has a good point. On the other hand, the DNN was upgraded by true professionals. I'm sure they know their trade.
My point was
Has anyone observed such a behaviour? It happens only after logging into an upgraded (not installed) system. Presumably, the Install and Upgrade packages have different JavaScript structures.
All the best,
Roman
Posted By Roman U. on 11/15/2023 9:56 AM
[...] Presumably, the Install and Upgrade packages have different JavaScript structures.
Hi Roman,
afaik, the difference between the install and the upgrade package is that there is no web(dot)config file in the latter. Everything else is the same.
Even true pros make mistakes sometimes, but it's good to have someone you can trust... ;-)
Maybe they forgot to unblock one of the upgrade packages ZIP file before extracting. I would try to go back to the start, upgrade the first step, try if it works, then upgrade the second step and so on.
Hi all,
I have this problem too.
It's a bug of the 9.13 version (see https://github.com/dnnsof...Platform/issues/5839 for more informations).
The 9.13.1 should fix it.
Posted By Stephane Tetard on 11/15/2023 9:06 AM
Hi all,
and just confirming I see this as well on my 9.13.0 sandbox site
Justin and Stephane,
Thank you! I can sleep at last )) I thought my installation was corrupt.
