Blank login page upgrading from 07.03.04 (45) to 8.0.4.226
I have tried everything I can think of to get the portal to come up.  I have tried create a second subsite.  I have tried changing templates.  Renaming the default template ect. Nothing seems to work
Did you directly upgrade or first to 7.4.2?
https://dnndocs.com/conte...rade-path/index.html
I have tired it both ways. I can upgrade too 7.4.2 and the login still displays. As soon as I cross over to DNN 8 the login page stops rendering.
Are you using a custom login page, or the standard login? If you are using a custom page, does the standard login work when you change it to this?
Are there any Java Script errors in the web developer console? Can you also check the source of the page, does it has any html code responsible for rendering login module?
I have the website configured to use the standard login page and and active directory.  I have tried disabling the active directory login before upgrade an it makes no difference.  The login page will not render it is is the standard login or active directory login.  or a new subsite.
I will check for javascrip errors.  I dont see any of the code responsible for rendering the login module.  Its like the module is gone the title renders but then the actual content for the login is blank.
