Hello, its old case, already discussed here.
Issue with my platform persist, now I got more time and will to solve it... After upgrade 7.04.01 to 7.04.02 (or 8.0.4.226) there is logged following exception in *.log.resources: 2020-01-23 10:39:43,082 [xyz][Thread:17][ERROR] DotNetNuke.Services.Exceptions.Exceptions - System.Threading.ThreadAbortException: Thread was being aborted. at System.Threading.Thread.SleepInternal(Int32 millisecondsTimeout) at System.Threading.Thread.Sleep(Int32 millisecondsTimeout) at System.Threading.Thread.Sleep(TimeSpan timeout) at DotNetNuke.Services.Scheduling.Scheduler.CoreScheduler.RunEventSchedule(EventName eventName) 2020-01-23 10:39:43,175 [xyz][Thread:17][FATAL] DotNetNuke.Web.Common.Internal.DotNetNukeHttpApplication - System.Web.HttpException (0x80004005): Request timed out.
I believe, if i manage to use debugger and get exceptions details like eventName, it can help to solve it. But I have experience only with creating/debugging c# winforms/console apps. Can someone give me brief instructions how to debug IIS process in server ?
I got also idea to fresh-install latest version 9.4.4 and do Export Site Template in original platform and do "import" in new platform, but also failed with this :-( a) when do export and "include files" it somehow fail and both template files are corrupted (xml incomplete, resource file should have around 4GB, but export only around 1GB size) b) export without files done ok, but when I try import it in new platform, I got another exception (error parsing site template). It should probably tell me that some extension is missing, but it doesn't. Any other workaround ?
Site runs normally, but there are some exceptions in Event Viewer, which are:
Message:DataType "Boolean" is not installed.
or
Message:DataType "String" is not installed
Message:The argument 'contentItemId' cannot be negative. Parameter name: contentItemId StackTrace: at DotNetNuke.Common.Requires.NotNegative(String argName, Int32 argValue) at DotNetNuke.Entities.Content.ContentController.GetContentItem(Int32 contentItemId) at DotNetNuke.Entities.Modules.ModuleController.IsSharedModule(ModuleInfo module) at DotNetNuke.Entities.Tabs.TabChangeTracker.TrackModuleModification(ModuleInfo module, Int32 moduleVersion, Int32 userId) at DotNetNuke.Entities.Modules.ModuleController.UpdateTabModuleOrder(Int32 tabId)
Message:Error rendering URLControl subcontrols. StackTrace: InnerMessage:Input string was not in a correct format. InnerStackTrace: at System.Number.StringToNumber(String str, NumberStyles options, NumberBuffer& number, NumberFormatInfo info, Boolean parseDecimal) at System.Number.ParseInt32(String s, NumberStyles style, NumberFormatInfo info) at DotNetNuke.Web.UI.WebControls.DnnUrlControl.DoRenderTypeControls() at DotNetNuke.Web.UI.WebControls.DnnUrlControl.OnPreRender(EventArgs e)
Unfortunatelly they don't say which module/page cause this.
