CKEditor issues when upgrading from DNN 9.1.1 to 9.2.2
Hi -
I'm working on upgrading from DNN 9.1.1 to 9.2.2 (on a test website) and seeing a number of issues.
Html Editor doesnt work after upgrade - I have CKEditor Editor Provoder 2.1.3 installed. I will print the error below (can I attach a file here?). Should I upgrade CK editor before I upgrade to DNN 9.2.2?
Also (and this persists on my site from before the upgrade) when I go to Site Settings > Site Behavior > More > Open HTML Editor Manager, I get a 404 error. Anyone know how this might be remedied?
Thanks for any help you may provide!
Tom
-------------Error  from HTML editor ----------------------------------------------------------------------------------------------------
ModuleId:-1
ModuleDefId:-1
FriendlyName:
ModuleControlSource:
AbsoluteURL:/Default.aspx
ExceptionGUID:8e5449cf-0efc-4a0c-bc0a-606f5882715a
AssemblyVersion:9.2.2
PortalId:0
UserId:389
TabId:40
RawUrl:/Home/tabid/40/ctl/Edit/mid/5951/Default.aspx?popUp=true
Referrer:http://sccinternettest.co.santa-cruz.ca.us/
UserAgent:Mozilla/5.0 (Windows NT 10.0; WOW64; Trident/7.0; rv:11.0) like Gecko
ExceptionHash:wjhj42OsizoewbfHlACe+xJRtDQ=
Message:Method not found: 'Void DotNetNuke.Framework.CDefault.AddStyleSheet(System.String, System.String)'.
StackTrace:
InnerMessage:Method not found: 'Void DotNetNuke.Framework.CDefault.AddStyleSheet(System.String, System.String)'.
InnerStackTrace:
   at WatchersNET.CKEditor.Web.CKEditorControl.RegisterCKEditorLibrary()
   at WatchersNET.CKEditor.Web.CKEditorControl.CKEditorInit(Object sender, EventArgs e)
   at System.Web.UI.Control.OnInit(EventArgs e)
   at System.Web.UI.Control.AddedControl(Control control, Int32 index)
   at DotNetNuke.UI.UserControls.TextEditor.OnLoad(EventArgs e)
Source:
FileName:
FileLineNumber:0
FileColumnNumber:0
Method:
Server Name: SCTAS35
Hi again -
Looks like I fixed the HTML Editor error, by updating the web.config to use:
[htmlProvider defaultProvider="DNNConnect.CKE"]
instead of:
[htmlEditor defaultProvider="CKHtmlEditorProvider"]
-Tom
