Error DNNSharp AF after upgrade to DNN971
We upgraded our DNN website to DNN 9.7.1. (with AF version 5.7.16) and now we get this error:
[NullReferenceException: Object reference not set to an instance of an object.]
   DnnSharp.Common.InitCommonDlls.Utils.WebConfig..ctor() +155
   DnnSharp.Common.InitCommonDlls.AppStartup.ExecuteStartupTasks() +296
   DnnSharp.Common.InitCommonDlls.AppStartup.Initialize() +8
[InvalidOperationException: The pre-application start initialization method Initialize on type DnnSharp.Common.InitCommonDlls.AppStartup threw an exception with the following error message: Object reference not set to an instance of an object..]
   System.Web.Compilation.BuildManager.InvokePreStartInitMethodsCore(ICollection`1 methods, Func`1 setHostingEnvironmentCultures) +890
   System.Web.Compilation.BuildManager.InvokePreStartInitMethods(ICollection`1 methods) +167
   System.Web.Compilation.BuildManager.CallPreStartInitMethods(String preStartInitListPath, Boolean& isRefAssemblyLoaded) +133
   System.Web.Compilation.BuildManager.ExecutePreAppStart() +178
   System.Web.Hosting.HostingEnvironment.Initialize(ApplicationManager appManager, IApplicationHost appHost, IConfigMapPathFactory configMapPathFactory, HostingEnvironmentParameters hostingParameters, PolicyLevel policyLevel, Exception appDomainCreationException) +746
[HttpException (0x80004005): The pre-application start initialization method Initialize on type DnnSharp.Common.InitCommonDlls.AppStartup threw an exception with the following error message: Object reference not set to an instance of an object..]
   System.Web.HttpRuntime.FirstRequestInit(HttpContext context) +552
   System.Web.HttpRuntime.EnsureFirstRequestInit(HttpContext context) +122
   System.Web.HttpRuntime.ProcessRequestNotificationPrivate(IIS7WorkerRequest wr, HttpContext context) +737
Looks like the latest version of DNNSharp Action Form isn't compatible with DNN 9.7.1.
I assume DNNSharp will release a fix within the next days
Go back and check the release notes for 9.7.1. There was a problem that surfaced after release, and a work-around has been posted. I don't know if this problem is the one affecting you, but you should check.
You should also contact support at DNNSharp regarding this issue. They should be able to help you, including updating the module if that is necessary. (I would say don't make assumptions, but make sure that they know about this.)
Reaction of DNNSharp:
We were able to reproduce that there are issues with our products and 9.7.
A fix for the issue you mention is possible late next week at the earliest and maybe as long as several weeks away.
Were you provided with a solution?
You can always check the DNNSharp website.
Already did Joe. THey provide links to the download site which has a HotFix and a stable version
https://www.dnnsharp.com/...d?p=AFORM&v=05.07.17
https://www.dnnsharp.com/...d?p=AFORM&v=05.09.11
Not clear if these are the solution but leads to a new question. How can I load these if I can't get to the UI to install the extension? I've tried overlaying the 9.7.1 upgrade package and including the hot fix into the install/ module directory but when I try to run the upgradewizard I get the regular .Net error page.
Is there a way for me to install this hot fix if the site isn't coming up?
Exception Details: System.NullReferenceException: Object reference not set to an instance of an object.
Source Error:
<code>An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.</code>
Stack Trace:
<code>
&#91;NullReferenceException: Object reference not set to an instance of an object.&#93;
&#91;InvalidOperationException: The pre-application start initialization method Initialize on type DnnSharp.Common.InitCommonDlls.AppStartup threw an exception with the following error message: Object reference not set to an instance of an object..&#93;
&#91;HttpException (0x80004005): The pre-application start initialization method Initialize on type DnnSharp.Common.InitCommonDlls.AppStartup threw an exception with the following error message: Object reference not set to an instance of an object..&#93;
   System.Web.HttpRuntime.ProcessRequestNotificationPrivate(IIS7WorkerRequest wr, HttpContext context) +737</code>
Does that mean that you are unable to get to the Personal Bar's Extensions page?
Posted By Santiago on 15 Nov 2020 02:36 PM
Yes, there are new versions which you need to install before upgrading DNN
