Error occurring on Dnnspot.Sitemap module while Upgrading to latest version
Page 2 of 2 << < 12
Hi Joe,
Pardon me but I can't share it as it's a production copy set up on my local environment. Are my settings seem to be OK? or is there any problem inside the setting configuration? Or any other suggestions that you can give would be appreciated.
I completely understand about showing the site.
For fun, remove the settings for Node XML path and Node selection expression. Enter a setting only for Menu style.
Yes, I am getting node information in xml : (I have just changed the titles only!)
PS: There are other pages in the site too but it shows only few of them. No wonder why!
Update: I am not able to put my xml correctly in the comment
Perhaps page view permissions?  Try logging on as super user and see if that shows more.
Okay, that I can handle afterwards. So, do you think there is some issue inside the xslt template or menudef xml?
Probably not.
Does DumpXML show all of your DNN pages?
Stick with the simplest possible configuration, and use NodeSelector, IncludeNodes, and ExcludeNodes if you want to limit what is shown on your page.
Hi Joe,
I am now able to get the link of the pages which I want through ULTokens. I just mentioned the Menu Style and nothing more, I hope the stylesheets will be applied after changes inside it.
Many thanks for all your support!! If I am stuck between any configuration related to styles, will ask you here. Thanks a lot.
I'm glad that you got this worked out.
Page 2 of 2 << < 12
