Error while upgrading from DNN 07.04.02 to 09.13.03
I've been on a path to upgrade DNN to a more modern version.
This has all been done on a seperate test instance I've setup to verify the steps and make sure everything is working properly, so this error isn't an emergency.
I've followed the recommended version upgrade path, from my current version, which is as follows:
07.04.02 -> 08.00.04 -> 09.01.01 -> 09.03.02 -> 09.13.03
The previous updates went fine, with some minor issues I've worked through. However, I've just upgraded to 09.13.03 and am now getting a server error (listed below).
Things I've tried:
Updating the .NET framework to 4.8.
Adding a dependentAssembly item to the web config:
Any help would be appreciated, thanks!
Cannot resolve dependency to assembly 'Microsoft.Extensions.DependencyInjection.Abstractions, Version=2.1.1.0, Culture=neutral, PublicKeyToken=adb9793829ddae60' because it has not been preloaded. When using the ReflectionOnly APIs, dependent assemblies must be pre-loaded or loaded on demand through the ReflectionOnlyAssemblyResolve event.
Exception Details: System.IO.FileLoadException: Cannot resolve dependency to assembly 'Microsoft.Extensions.DependencyInjection.Abstractions, Version=2.1.1.0, Culture=neutral, PublicKeyToken=adb9793829ddae60' because it has not been preloaded. When using the ReflectionOnly APIs, dependent assemblies must be pre-loaded or loaded on demand through the ReflectionOnlyAssemblyResolve event.
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
Stack Trace:
[FileLoadException: Cannot resolve dependency to assembly 'Microsoft.Extensions.DependencyInjection.Abstractions, Version=2.1.1.0, Culture=neutral, PublicKeyToken=adb9793829ddae60' because it has not been preloaded. When using the ReflectionOnly APIs, dependent assemblies must be pre-loaded or loaded on demand through the ReflectionOnlyAssemblyResolve event.]
   System.Reflection.RuntimeAssembly.GetType(RuntimeAssembly assembly, String name, Boolean throwOnError, Boolean ignoreCase, ObjectHandleOnStack type) +0
   System.Reflection.RuntimeAssembly.GetType(String name, Boolean throwOnError, Boolean ignoreCase) +50
   Owin.Loader.DefaultLoader.GetDefaultConfigurationString(Func`2 defaultTypeNames) +963
   Owin.Loader.DefaultLoader.LoadImplementation(String startupName) +154
   Owin.Loader.DefaultLoader.Load(String startupName) +23
   Microsoft.Owin.Host.SystemWeb.OwinBuilder.Build() +95
   System.Lazy`1.CreateValue() +711
   System.Lazy`1.LazyInitValue() +436
   Microsoft.Owin.Host.SystemWeb.OwinHttpModule.Init(HttpApplication context) +86
   System.Web.HttpApplication.RegisterEventSubscriptionsWithIIS(IntPtr appContext, HttpContext context, MethodInfo[] handlers) +573
   System.Web.HttpApplication.InitSpecial(HttpApplicationState state, MethodInfo[] handlers, IntPtr appContext, HttpContext context) +168
   System.Web.HttpApplicationFactory.GetSpecialApplicationInstance(IntPtr appContext, HttpContext context) +277
   System.Web.Hosting.PipelineRuntime.InitializeApplication(IntPtr appContext) +369
[HttpException (0x80004005): Cannot resolve dependency to assembly 'Microsoft.Extensions.DependencyInjection.Abstractions, Version=2.1.1.0, Culture=neutral, PublicKeyToken=adb9793829ddae60' because it has not been preloaded. When using the ReflectionOnly APIs, dependent assemblies must be pre-loaded or loaded on demand through the ReflectionOnlyAssemblyResolve event.]
   System.Web.HttpRuntime.FirstRequestInit(HttpContext context) +532
   System.Web.HttpRuntime.EnsureFirstRequestInit(HttpContext context) +114
   System.Web.HttpRuntime.ProcessRequestNotificationPrivate(IIS7WorkerRequest wr, HttpContext context) +724
Version Information: Microsoft .NET Framework Version:4.0.30319; ASP.NET Version:4.8.4110.0
DNN7 to DNN9......be brave! I presume the upgrades went well and then you get an error from DNN9.3 to DNN9.13 Version DNN9.4 did move to .Net 4.7.2 I wonder if a module on the installation is not compatible and needs a new/recompiled version.
We have had issues with errors appearing based on version and it was a module that needed to be updated, but the error messages were odd and not helping. Maybe this is one of those cases?
You could try editing the DNN9.3 version to remove the 3rd party modules and retry the upgrade. If it works you know it's a module that is the problem. Then it's a nasty case of finding the problem module by removing 1 by 1 and retesting the upgrade form DNN9.3 to DNN9.13.
Sorry not very helpful, I hope someone has a better suggestion for you. Good Luck.
That's not too old of a version to upgrade from, in my opinion.  I've upgraded some 4.x sites in recent history and we're about to do another one of those soon.  😴
Anyhow, it sounds like there might be a missing DLL or a permissions issue that isn't allowing the DLL to be used by the web application.  I'd recommend starting over and reapplying permissions as you go, assuming the DLL is indeed there.
Also, be sure to run Windows update to be sure all updates to the .NET Framework are applied.
Thanks for the support, I was finally able to complete this upgrade.
I first went through the process of just installing a resh DNN 9.13 site, to verify the server itself was able to host it, and that went fine.
I went back and uninstlaled a bunch of extensions on my site before doing the final update, and after doing that, the update was successfull.
I need to go back and do it again, to make sure I know the exact extensions I had uninstalled for my future production update, so once I have the list, I'll add them here in case anyone else has this same problem.
If memory serves good, we had in the past some issues where both DNN and 3rd party extensions might have been using different versions of that library and we did not yet have it as a package (upgradeable). I think one of those 3rd party extensions was 2sxc and there needed to be a correct order of when to update DNN and when to update 2sxc. I can't remember the exact details (so don't quote me on this) but I think you had to go to DNN 9.3.2, then update 2sxc and then continue on.
That's a really good point from Daniel.  Of course, you should always upgrade any third-party/custom extensions before upgrading whenever possible.
If a third-party module is not built against an appropriate version of DNN, and the correct .NET Framework, it can throw some odd challenges your way.  Daniel just reminded me of some frustrating upgrades in the past. 😎
