Inporting users from a DNN 7 into a DNN 9 with passwords
Hello friends,
I have to import the users from a DNN 7 organization into a new DNN 9.8.0  organization with passwords, too.
I have performed the task using SQL batches, inserting data into [dbo].[Users], [dbo].[UserRoles],[dbo].[UserPortals],[dbo].[UserProfile],[dbo].[aspnet_Users],[dbo].[aspnet_Membership].
All good except that the users cannot login into the site using their passwords.
The passwords are hashed so , i am afraid that is not enough to do the copy/paste ( select/insert) :).
Is there a way to migrate the old passwords in order to not force the all users to change their passwords?
Thank you,
If the passwords are hashed (which began by default I believe in 7.2 and above) then you will not be able to migrate them.
Are the passwords lost when an upgrade in place is done? If not, why we cannot import them too from one implementation to another ?
If you upgrade in place, the passwords stay the same.
Thank you Michael for your answer.
Can you explain to me, please, why the same passwords (I am taking about the hashes that I have copied by select/insert) does not work on the new implementation (9.8.0)? Isn't the same mechanism of authentication ? Isn't the same mechanism of encription ?
You should be able to use https://github.com/fordnn/usersexportimport to export users from your DNN7 installation import them into a DNN9 installation.
You can export passwords from DNN7 and then import them into DNN9.
What you can't do is export passwords from DNN 9. They are encrypted and cannot be recovered. This is a security feature in DNN 9.
Try copying the machine key from web.config to the new install. That would work with encrypted passwords. I not sure with hashed passwords but it's worth a shot and easy to test.
Even if they are not saved in clear in database ?
The passwords are hashed in our DNN 7.
Thank you,
As far as I know the DNN membership provider is using the machine key when encrypting the passwords. If the machine key changes (i.e. your import into another DNN instance) it becomes impossible to decrypt. I would think that it's the same with hashed passwords.
Thank you all,
The solution was to copy the machine key in web.config.
The passwords are encrypted , only encryption is using the machine key. I don't thing that hashing use a key.
