Issue in ResourceManager after upgrading from 9.13.9 to 10.1.2
Team,
We are not able to give permission to a secure folder in resource manager by roles other than "Administrators". We have custom role in our application and have exposed Resource Manager to manage content of the application. But after upgrading from 9.13.9 to 10.2.1, on trying to give permission to a folder getting follwoing error: "Error: Unauthorized". It is failing on call of this api -> Items/GetRoleGroups
In ItemsController.cs I can see following line which is giving this error:
 [HttpGet]
        [ValidateAntiForgeryToken]
        public IHttpActionResult GetRoleGroups()
            if (!this.UserInfo.IsInRole(this.PortalSettings.AdministratorRoleName))
                return this.Unauthorized();
            var groups = RoleController.GetRoleGroups(this.roleProvider, this.PortalSettings.PortalId)
                            .Cast()
                            .Select(RoleGroupDto.FromRoleGroupInfo);
            return this.Ok(groups);
This functionality was earlier working in 9.13.9, is this intentional change? Also I failed to understand why this check was not in other API calls in this file? I think this is independent module and we should use module permission to identify if any such security check is required.
Can you please look into it urgently.
Regards,
Alok
That code has not changed in 4 years, it probably is something deeper in what this code calls and will need some investigation.
You can create an issue at https://github.com/dnnsof.../Dnn.Platform/issues but as for the urgency, keep in mind this is a free open-source product maintained by unpaid contributors.
