Issues after upgrading from DNN 9.13.9 to 10.1.2.0
Hello team,
I am getting few issues after upgrading our site from DNN 9.13.9 to 10.1.2.0.
1. In title "(Beta Version: 10.1.2.22)" is getting appended in page titles? Does that mean the version released is beta?
2. Getting errors like as below in admin log:
  • Message: Could not load type 'Dnn.PersonaBar.Library.DTO.UserSettings' from assembly 'Dnn.PersonaBar.Library, Version=10.1.2.0, Culture=neutral, PublicKeyToken=null'.
  • :Message: Could not load type 'Dnn.PersonaBar.Library.DTO.Permissions' from assembly 'Dnn.PersonaBar.Library, Version=10.1.2.0, Culture=neutral, PublicKeyToken=null'.
  • The EnablePartialRendering property cannot be changed after the Init event.
  • Method not found: 'System.Collections.Hashtable DotNetNuke.Entities.Modules.ModuleController.GetModuleSettings(Int32)'. - Probably third party module need to be fixed and rebuilt here.
Can you give idea around issues, how can we fix them? Are they known bugs?
Alok, make sure you don't use a beta version for production environment, you must get the latest version from this link; as of today the latest one you can use is V10.1.2.
 Now, about the errors: make sure you got a compatible version with v10.1.2 for all your third party modules before starting the upgrade process.
After you do this, let us know if you got new errors after running the upgrade process once again.
Alok, sorry I had to delete your post. Please read the forums rules just below, you have just violated point #1. Do not post potential security issues in public channels.
You can report them instead here https://github.com/dnnsof...nn.Platform/security where they can be discusses/remediated in private.
However, those CVEs don't really make sense from versioning perspectives a CVE-2021-xxxx cannot be introduced in v10.1.2 as that version did not even exist in 2021, so I guess the scanning tool might be having a false positive on that.
