Listx Module Not Found In 8.0 version
Hi
I have upgraded 4.9 to 8.0 but listx module is not woking. when we upgraded we got  one error  Could not load type 'DotNetNuke.UI.WebControls.SolPartActions so we removed with the help of below link
https://stackoverflow.com...trols-solpartactions . Upgradation was successfull. But the edit module and add module option is missing . My major pages are using listx control since edit option is missing i am not able to move ahead. can someone can provide a solution. Am i missing some points ? Please help ?
did you upgrade directly or did you follow the suggested upgrade path?
I have never heard of a ListX module, so propably this is a third party component. The propability is high enough that it uses some deprecated methods, and therefore does not work anymore. You should contact the vendor, and install an upgrade.
ListX is the former name of http://openwebstudio.com/
Hi, Even i am facing a similar issue. My majority of pages are using Listx module. we are not DNNable to do the upgrade.
You have a long road ahead of you, I'm afraid.
As has been pointed out, ListX has be "replaced" by Open Web Studio. I think that module has been kept up to date, but I'm not sure if it is a direct replacement or upgrade.
As for the SolPart issue, the SolPartMenu also has disappeared. There was a fairly simple way to replace it, and that means may be in DNN 8. I can't remember. This link may help if the data is still there: https://www.dnnsoftware.com/wiki/ddrmenu.
Moving up to DNN 9, you will find some other issues. But, I think that your first set of issues is to get things running with DNN 8. If ListX to OWS works, then you may have a somewhat direct path. If not, you'll have to do some redevelopment and, in that case, it might be simpler to start with a clean install of DNN 9.9.1 and redevelop the site. Instead of ListX/OWS you might want to consider 2sxc or OpenContent as these are more modern solutions.
Feel free to continue to ask us questions so that we can help you figure out the best path.
