Persona Bar issues after update
Hey All,
We recently started using DNN. We have several sites on this platform. I'm an admin for a DNN site that running now latest version, but when i did the last upgrade I think I blew up the user registration module that was being utilized. Immediately, I grabbed the backup I created of the website and placed it back in the correct directory, while deleting the upgraded website. After this, the registration bar was working but the Persona Bar had disappeared.
Do you have any tips on how to fix this and so that it doesn't happen again?
Regards, Boris Vivienne
work time - employee monitoring software
In reverting, dis you revert both the database and all of the files? That should have left you with an installation that was a copy of the site before you did the second update.
Did you run the complete upgrade again? If not, you should restore the database, delete the entire files directory and replace with the files backup. Then, copy the upgrade files and the installation should run again.
I don't understand your comments about the registrations module, though. Can you explain that part?
