Problem adding Resource Manager Module to Page
Hi
I have just upgraded to DNN 9.10.2 and I am trying to proceed with the Telerik removal as per the instructions.
https://docs.dnncommunity...k-removal/index.html
 I have installed the resource Manager Module via the extensions Page and removed the Digital Assets Management Module from the Site assets page.
My issue starts when trying to add an instance of the Resource Manager Module to the page which gives me the following error;
Error: ResourceManager is currently unavailable. DotNetNuke.Services.Exceptions.ModuleLoadException: c:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files\xxxxxx\4da5f5f9\f1bf0673\App_LocalResources.resourcemanager.db1308d2.rlzmmpwo.0.cs(39): error CS0542: 'ResourceManager': member names cannot be the same as their enclosing type ---> System.Web.HttpCompileException: c:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files\xxxxxx\4da5f5f9\f1bf0673\App_LocalResources.resourcemanager.db1308d2.rlzmmpwo.0.cs(39): error CS0542: 'ResourceManager': member names cannot be the same as their enclosing type at System.Web.Compilation.AssemblyBuilder.Compile() at System.Web.Compilation.BuildProvidersCompiler.PerformBuild() at System.Web.Compilation.CodeDirectoryCompiler.GetCodeDirectoryAssembly(VirtualPath virtualDir, CodeDirectoryType dirType, String assemblyName, StringSet excludedSubdirectories, Boolean isDirectoryAllowed) at System.Web.Compilation.BuildManager.CompileCodeDirectory(VirtualPath virtualDir, CodeDirectoryType dirType, String assemblyName, StringSet excludedSubdirectories) at System.Web.Compilation.BuildManager.EnsureFirstTimeDirectoryInit(VirtualPath virtualDir) at System.Web.Compilation.BuildManager.GetBuildResultFromCacheInternal(String cacheKey, Boolean keyFromVPP, VirtualPath virtualPath, Int64 hashCode, Boolean ensureIsUpToDate) at System.Web.Compilation.BuildManager.GetVPathBuildResultFromCacheInternal(VirtualPath virtualPath, Boolean ensureIsUpToDate) at System.Web.Compilation.BuildManager.GetVPathBuildResultInternal(VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile, Boolean throwIfNotFound, Boolean ensureIsUpToDate) at System.Web.Compilation.BuildManager.GetVPathBuildResultWithNoAssert(HttpContext context, VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile, Boolean throwIfNotFound, Boolean ensureIsUpToDate) at System.Web.UI.TemplateControl.LoadControl(VirtualPath virtualPath) at DotNetNuke.UI.ControlUtilities.LoadControl[T](TemplateControl containerControl, String ControlSrc) at DotNetNuke.ModulePipeline.ModuleControlPipeline.LoadModuleControl(TemplateControl containerControl, ModuleInfo moduleConfiguration) at DotNetNuke.UI.Modules.ModuleHost.LoadModuleControl() --- End of inner exception stack trace ---
Could any provide any advice, guidance or assistance please.
Many thanks
Which version of .NET Framework is your site using?
