Problem whilst upgrading from 10.2.1 to 10.2.5
Using the new update method, it extracted the files, prompted to proceed with update, then i got a blank screen. Checking the event log, i had a message of
'A process serving application pool 'dnnapppool' suffered a fatal communication error with the Windows Process Activation Service'
The files in the website folder have been updated, there is an install folder , so decided to run /install/upgradewizard.aspx , this brought up the familar installation screen, which completed successfully.
Results from logfile:-
{"progress":0,"details":"Upgrade Started at:11/16/2026 4:50:36 PM","check0":"NotStarted","check1":"NotStarted"}
{"progress":0,"details":"Checking IIS configuration","check0":"NotStarted","check1":"NotStarted"}
{"progress":17,"details":"Upgrading Application","check0":"Running","check1":"NotStarted"}
{"progress":50,"details":"Installing Library - AspNetMvc_5.3.61130.707_Install.zip","check0":"Done","check1":"Running"}
{"progress":50,"details":"Installing Library - AspNetWebApi_5.3.61130.707_Install.zip","check0":"Done","check1":"Running"}
{"progress":50,"details":"Installing Library - AspNetWebPages_3.0.61130.707_Install.zip","check0":"Done","check1":"Running"}
{"progress":51,"details":"Installing Library - MailKit_4.8.0.0_Install.zip","check0":"Done","check1":"Running"}
{"progress":51,"details":"Installing Library - Microsoft.Extensions.DependencyInjection_8.0.23.53103_Install.zip","check0":"Done","check1":"Running"}
{"progress":52,"details":"Installing Library - Microsoft.Extensions.FileSystemGlobbing_5.0.20.51904_Install.zip","check0":"Done","check1":"Running"}
{"progress":52,"details":"Installing Library - Microsoft.Web.Infrastructure_2.0.34876.0_Install.zip","check0":"Done","check1":"Running"}
{"progress":53,"details":"Installing Library - Newtonsoft.Json_13.0.3.27908_Install.zip","check0":"Done","check1":"Running"}
{"progress":53,"details":"Installing Library - SharpZipLib_1.4.2.13_Install.zip","check0":"Done","check1":"Running"}
{"progress":54,"details":"Installing Library - WebFormsMvp_1.4.5.0_Install.zip","check0":"Done","check1":"Running"}
{"progress":54,"details":"Installing Module - DDRMenu_10.02.05_Install.zip","check0":"Done","check1":"Running"}
{"progress":55,"details":"Installing Library - Dnn.EditBar.UI_10.02.05_Install.zip","check0":"Done","check1":"Running"}
{"progress":55,"details":"Installing Library - Dnn.PersonaBar.UI_10.02.05_Install.zip","check0":"Done","check1":"Running"}
{"progress":56,"details":"Installing Connector - DNNCE_AzureConnector_10.02.05_Install.zip","check0":"Done","check1":"Running"}
{"progress":56,"details":"Installing Module - DNNCE_Console_10.02.05_Install.zip","check0":"Done","check1":"Running"}
{"progress":57,"details":"Installing Module - DNNCE_CoreMessaging_10.02.05_Install.zip","check0":"Done","check1":"Running"}
{"progress":57,"details":"Installing Module - DNNCE_HTML_10.02.05_Install.zip","check0":"Done","check1":"Running"}
{"progress":58,"details":"Installing Module - DNNCE_HtmlEditorManager_10.02.05_Install.zip","check0":"Done","check1":"Running"}
{"progress":58,"details":"Installing Module - DNNCE_Journal_10.02.05_Install.zip","check0":"Done","check1":"Running"}
{"progress":59,"details":"Installing Module - DNNCE_MemberDirectory_10.02.05_Install.zip","check0":"Done","check1":"Running"}
{"progress":59,"details":"Installing Module - DNNCE_RazorHost_10.02.05_Install.zip","check0":"Done","check1":"Running"}
{"progress":60,"details":"Installing Module - DNNCE_ResourceManager_10.02.05_Install.zip","check0":"Done","check1":"Running"}
{"progress":60,"details":"Installing Library - DNNCE_SiteExportImport_10.02.05_Install.zip","check0":"Done","check1":"Running"}
{"progress":61,"details":"Installing Module - DNNCE_SocialGroups_10.02.05_Install.zip","check0":"Done","check1":"Running"}
{"progress":61,"details":"Installing Module - DNNCE_TelerikRemoval_10.02.05_Install.zip","check0":"Done","check1":"Running"}
{"progress":62,"details":"Installing Connector - GoogleAnalytics4Connector_10.02.05_Install.zip","check0":"Done","check1":"Running"}
{"progress":62,"details":"Installing Connector - GoogleAnalyticsConnector_10.02.05_Install.zip","check0":"Done","check1":"Running"}
{"progress":63,"details":"Installing Connector - GoogleTagManagerConnector_10.02.05_Install.zip","check0":"Done","check1":"Running"}
{"progress":63,"details":"Installing Skin - Aperture_10.2.5_install.zip","check0":"Done","check1":"Running"}
{"progress":64,"details":"Installing Provider - AspNetClientCapabilityProvider_10.02.05_Install.zip","check0":"Done","check1":"Running"}
{"progress":64,"details":"Installing Library - DNNCE_ExchangeOnlineAuthProvider_10.02.05_Install.zip","check0":"Done","check1":"Running"}
{"progress":65,"details":"Installing Provider - DNNCE_FolderProviders_10.02.05_Install.zip","check0":"Done","check1":"Running"}
{"progress":65,"details":"Installing Library - DNNCE_GoogleMailAuthProvider_10.02.05_Install.zip","check0":"Done","check1":"Running"}
{"progress":66,"details":"Installing Provider - DNNConnect.CKEditorProvider_10.02.05_Install.zip","check0":"Done","check1":"Running"}
{"progress":66,"details":"Installing Provider - DnnJwtAuth_10.02.05_Install.zip","check0":"Done","check1":"Running"}
{"progress":67,"details":"Installing PersonaBar - Dnn.PersonaBar.Extensions_10.02.05_Install.zip","check0":"Done","check1":"Running"}
{"progress":67,"details":"Installing JavaScript_Library - DnnPlugins_10.02.05_Install.zip","check0":"Done","check1":"Running"}
{"progress":68,"details":"Installing JavaScript_Library - jQueryUI_01.14.01_Install.zip","check0":"Done","check1":"Running"}
{"progress":100,"details":"Upgrade Complete","check0":"Done","check1":"Done"}
There isn't a new record in the dbo.version table
When trying to run the website, i get the following:-
[MissingMethodException: Method not found: 'Void DotNetNuke.Entities.Controllers.HostController..ctor(DotNetNuke.Abstractions.Logging.IEventLogger, System.Lazy`1)'.]
   DotNetNuke.Web.Mvc.MvcHttpModule..cctor() +0
[TypeInitializationException: The type initializer for 'DotNetNuke.Web.Mvc.MvcHttpModule' threw an exception.]
   System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor) +0
   System.Reflection.RuntimeConstructorInfo.Invoke(BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture) +387
   Microsoft.Extensions.DependencyInjection.ConstructorMatcher.CreateInstance(IServiceProvider provider) +217
   Microsoft.Extensions.DependencyInjection.ActivatorUtilities.CreateInstance(IServiceProvider provider, Type instanceType, Object[] parameters) +371
   System.Web.HttpApplication.BuildIntegratedModuleCollection(List`1 moduleList) +234
   System.Web.HttpApplication.GetModuleCollection(IntPtr appContext) +1153
   System.Web.HttpApplication.RegisterEventSubscriptionsWithIIS(IntPtr appContext, HttpContext context, MethodInfo[] handlers) +139
   System.Web.HttpApplication.InitSpecial(HttpApplicationState state, MethodInfo[] handlers, IntPtr appContext, HttpContext context) +168
   System.Web.HttpApplicationFactory.GetSpecialApplicationInstance(IntPtr appContext, HttpContext context) +277
   System.Web.Hosting.PipelineRuntime.InitializeApplication(IntPtr appContext) +369
[HttpException (0x80004005): The type initializer for 'DotNetNuke.Web.Mvc.MvcHttpModule' threw an exception.]
   System.Web.HttpRuntime.FirstRequestInit(HttpContext context) +532
   System.Web.HttpRuntime.EnsureFirstRequestInit(HttpContext context) +111
   System.Web.HttpRuntime.ProcessRequestNotificationPrivate(IIS7WorkerRequest wr, HttpContext context) +719
The file DotNetNuke.Web.MVC.dll in the bin folder is version 10.2.5
Any suggestions where to look next to resolve this. Luckily this is a test site, so i can restore it at will.
