Upgrade 9.0.2 to 9.1.0 Dies RESX:PersonaBarMenu.Text Not Found During Persona
I am trying to upgrade a 9.0.2 DNN Platform to 9.1.0 and it dies with a missing resx.
I have tried everything. I have downloaded the source looking for 'RESX:PersonaBarMenu.Text' and it is not in the source. I have done full file scans (including into DLLs) of a clean 9.0.2 and my 9.0.2 with no success.  I have added this text to every reasonable resx file. I have overlaid the files in my 9.0.2 for all of persona directories, and made every single database entry the same as the clean 9.0.2. It still dies with the note below in the logs.
I found one entry in Lists DB that contains this word. But, this was in both 9.0.2 versions.
EntryID    ListName    Value    Text    ParentID    Level    SortOrder    DefinitionID    Description    PortalID    SystemList    CreatedByUserID    CreatedOnDate    LastModifiedByUserID    LastModifiedOnDate
5151    Installer    PersonaBarMenu    Dnn.PersonaBar.UI.Components.Installers.PersonaBarMenuInstaller, Dnn.PersonaBar.UI    0    0    0    0        -1    0    NULL    2017-04-04 11:32:30.900    NULL    2017-04-04 11:32:30.900
I really need a workaround for this.
Please Please. Any assistance will be appreciated.
2019-09-13 12:29:03,238 [Dev4][Thread:8][ERROR] DotNetNuke.Framework.Reflection - RESX:PersonaBarMenu.Text
System.Web.HttpException (0x80004005): Could not load type 'RESX:PersonaBarMenu.Text'.
   at System.Web.Compilation.BuildManager.GetType(String typeName, Boolean throwOnError, Boolean ignoreCase)
   at DotNetNuke.Framework.Reflection.CreateType(String TypeName, String CacheKey, Boolean UseCache, Boolean IgnoreErrors)
2019-09-13 12:29:03,332 [Dev4][Thread:8][FATAL] DotNetNuke.Web.Common.Internal.DotNetNukeHttpApplication - System.Web.HttpUnhandledException (0x80004005): Exception of type 'System.Web.HttpUnhandledException' was thrown. ---> System.ArgumentNullException: Value cannot be null.
Parameter name: type
   at System.Activator.CreateInstance(Type type, Boolean nonPublic)
   at System.Activator.CreateInstance(Type type)
   at DotNetNuke.Services.Installer.Installers.InstallerFactory.GetInstaller(String installerType)
   at DotNetNuke.Services.Installer.Installers.InstallerFactory.GetInstaller(XPathNavigator manifestNav, PackageInfo package)
   at DotNetNuke.Services.Installer.Installers.PackageInstaller.ReadComponents(XPathNavigator manifestNav)
   at DotNetNuke.Services.Installer.Installers.PackageInstaller.ReadManifest(XPathNavigator manifestNav)
   at DotNetNuke.Services.Installer.Installers.PackageInstaller..ctor(String packageManifest, InstallerInfo info)
   at DotNetNuke.Services.Installer.Installer.ProcessPackages(XPathNavigator rootNav)
   at DotNetNuke.Services.Installer.Installer.ReadManifest(Boolean deleteTemp)
   at DotNetNuke.Services.Upgrade.Upgrade.InstallPackage(String file, String packageType, Boolean writeFeedback)
   at DotNetNuke.Services.Install.Install.UpgradeApplication()
   at DotNetNuke.Services.Install.Install.OnLoad(EventArgs e)
   at System.Web.UI.Page.HandleError(Exception e)
   at System.Web.UI.Page.ProcessRequest(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
   at System.Web.UI.Page.ProcessRequest()
   at System.Web.UI.Page.ProcessRequest(HttpContext context)
   at System.Web.HttpApplication.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute()
Strange, I have never seens that.
Did you try 9.1.1 instead for 9.1.0?
Thanks for contributing.
I have tried upgrading every future version increment from 9.1.0 to 9.4.0. All with the same results.
I have tried installing 9.0.2 and copying over all database definitions, procedures, and data content for the persona database files.
It still dies in the exact same spot, but with a variety of errors all centered on that step.
My most recent is after copying all fresh 9.0.2 into the existing 9.0.2:
2019-09-16 19:05:15,075 [Dev4][Thread:49][FATAL] DotNetNuke.Web.Common.Internal.DotNetNukeHttpApplication - System.Web.HttpUnhandledException (0x80004005): Exception of type 'System.Web.HttpUnhandledException' was thrown. ---> System.ArgumentNullException: Value cannot be null.
what about that
I haven't seen that specific upgrade error for these versions before.  I've been able to upgrade numerous times directly to 09.01.01, though.  Have you tried that?  Also, I'd suggest merging updates in your web.config by comparing it to a clean instance of 09.00.02 before beginning.  It's possible you're missing something.
Hello
I hope you have solved your problem by now, but if not, I had a very similar problem that was caused by [code]add key="ShowMissingKeys" value="true"[/code] in my web.config. I removed the line and the upgrade worked.
Nicolas
