About 10 days ago I followed the upgrade path for 9.1.1 to 9.5.0, which I posted about. I did roll back to 9.1.1 using my backup database and directory.
All is working on all 18 sites, different skins on several sites, but one item that is not working is images.
When visiting each site most if not all the images are not displayed. I can login to each site, login as host and the images are displayed. When I logout most of the images are displayed. If I visit each page and Clear Cache, then logout the images are there. If I wait maybe an hour or more and revisit the site most images are not displayed. Last night I read an article where someone had a similar problem it it was suggested they clear the DNN\App_Data\ClientDependency and that worked.. last night, but this morning images are now gone.
Premissions on the ClientDependency folder are fine.
Nope, the images are ALL there... No 404... just blank image frame. I used Robocopy to copy the files from the previous DNN directory and maintained all permissions. The original 9.1.1 site has been working fine since around 2018.
FYI, even though it says "New Member" that is only because I just joined the new forums about a week ago. I have been on the old forums for years and started with DNN around version 1.
All images are displayed when I am logged in as Admin so I know they are there. I have a team meeting on with another group in about 3 minutes so I will try the Site Assets permisions later.
The other wierd part is if I am logged out and right click an image to "view image" it offers me the login screen. I do not login, but select the same menu item and all the images are then displayed....
Joe, I have never had this problem when I backed up database and directory in the past.
I do not believe I have ever looked at the Site Assets permissions so not sure what should be there...
Currently when I look at Site Assets permssions I see Role Administrators has a lock in "Broswe Files in Folder", "Open Files in Folder" and "Write to Folder". Both All Users and Registered Users are blank.
Thank you all for the suggestions. It did end up being a Windows server directory permissions problem, I failed to add one user to the DNN directory in the new instance. The new 9.1.1 instance and the upgraded instance are both working properly. The upgraded instance is running 9.6.0 RC1 and I will use it for testing the version.
Thanks again and special thanks to @ Joe Craig for prompting me to look closer at permissions.
One piece of advise to all who plan on upgrading....
First, make a backup of your current versions database and directory. MAKE SURE you upgrade all modules, skins, themes, containers, extensions and .NET Framework PRIOR to upgrading a site.
