Upgrade from 9.6 to 9.10 to 9.11 >> DDay.iCal DLL Errors
Hello everyone,
We have 2 site that we are trying to upgrade. The first site successfully upgraded from 9.6 to 9.10.  Then we tried to upgrade from 9.10 - 9.11 and got stuck on the "Security" page on the upgrade wizard. The second site started at 9.10 and when trying to upgrade to 9.11 it resulted in the same stuck on "Security" page problem.
In looking at the logs for both sites, the same error is thrown in their respective log files:
2024-07-12 08:14:06,785 [][Thread:1][ERROR] DotNetNuke.Web.Extensions.StartupExtensions - Unable to configure services for DDay.iCal, Version=1.0.2.575, Culture=neutral, PublicKeyToken=null, see exception for details
- LoaderException: Could not load file or assembly 'antlr.runtime, Version=2.7.6.2, Culture=neutral, PublicKeyToken=1790ba318ebc5d56' or one of its dependencies. The system cannot find the file specified.
We noticed that the 9.10 Upgrade ZIP did not have the DDay DLL but the 9.11 Upgrade ZIP does have this DDay DLL.
Can anyone please provide any insights as to why it is there, and what problem the 9.11 upgrade is trying to solve by including this library?  Also should there be an "antlr.DLL" file in this 9.11 Upgrade ZIP?  If not, should we try to find it somewhere and include it?  Is there a different path towards moving through this issue?
Thank you!
First of all, there is a more tested upgrade path documented here https://docs.dnncommunity...rade-path/index.html
So you should upgrade to 9.13.3 directly instead of 9.11.0 as more people have tested this scenario.
Secondly, I am not aware of either DDay.iCal or antlr being DNN dependencies, when you say you found it in the upgrade package, where did you download that package from and in which path did you find that file ?
Hi Daniel, thanks for the reply. Apologies, as it turns out that we were incorrect regarding the DDay.iCal DLL. It was part of our DNN site, and not part of the upgrade package. As per your recommendation we are going to fast track the upgrade to 9.13.3 and see how that turns out.
Ok, so before you go to far though, I would start with 3 things:
1: Check if there are any unused extensions you could remove before upgrading
2: For the extensions that are left (and 3rd party) I would check if they have updates available that are still compatible with you starting DNN version
3: I would try to figure out which module is using that dll. If it was installed properly, you will have that dll listed in the database table called "Assemblies". When you find it, take note of the PackageID for it and then look into the "Packages" table for that ID and in the Name you should see what extension that is. From there you can take a look if that has updates available or if that extension was maintained recently to support newer DNN versions.
The DDay.iCal looks to be very old and obsolete now, it looks like they have moved to iCal.Net. It's probably a third party module. If the direct upgrade does not work you can try uninstalling the module that uses DDay.iCal, if the module has been done correctly the assembly should also be removed. (Be careful of dependencies) Then try the upgrade. Of course this method will probably remove data from your database and maybe the filesystem so you may need to deal with exporting and importing data from your database. Sometime simply saving data in a temporary table in the database is easy and simple, sometime not.
This approach should be a last resort. But sometimes it's an option that can work.
Good luck.
I have seen this issue too, IIRC I just removed the DDay.iCal dll and my upgrade worked.
I concluded it was a left-over from an old third party extension I previously uninstalled
Now that Timo mentions it, this rings a bell, an old module which left that behind. Of course, follow best practices and cleanup using the UI first, but if it stays and is not referenced, probably deleting it is the correct way.
