Upgrade issue from 07.00.06 to 07.04.02 -> Value can't be null
I  got the below issue when i start upgrade from 07.00.06 to 07.04.02. can you anyone suggest me to resolve this?
Logs :
Current Assembly Version: 07.04.02
Current Database Version: 07.00.06
Upgrade Status Report
00:00:00.043 - Upgrading to Version: 07.04.02
00:00:00.091 -   Executing Script:07.01.00.SqlDataProvider Success
00:00:06.596 -   Executing Script:07.01.01.SqlDataProvider Success
00:00:06.831 -   Executing Script:07.01.02.SqlDataProvider Success
00:00:07.290 -   Executing Script:07.02.00.SqlDataProvider Success
00:00:09.071 -   Executing Script:07.02.01.SqlDataProvider Success
00:00:12.772 -   Executing Script:07.02.02.SqlDataProvider Success
00:00:16.560 -   Executing Script:07.03.00.SqlDataProvider Success
00:00:17.389 -   Executing Script:07.03.01.SqlDataProvider Success
00:00:17.435 -   Executing Script:07.03.02.SqlDataProvider Success
00:00:18.295 -   Executing Script:07.03.03.SqlDataProvider Success
00:00:25.272 -   Executing Script:07.03.04.SqlDataProvider Success
00:00:26.853 -   Executing Script:07.04.00.SqlDataProvider Success
00:00:29.324 -   Executing Script:07.04.01.SqlDataProvider Success
00:00:29.905 -   Executing Script:07.04.02.SqlDataProvider Success
00:00:30.418 -   Executing Script:07.04.02.01.SqlDataProvider Success
00:00:30.450 -   Updating Config Interval Files: 07.04.02.01 Success
00:00:30.477 -   Cleaning Up Files: 07.04.02.01 Success
00:00:30.524 -   Application Upgrades : 07.01.00
00:00:30.813 -   Converting old Folders to new format. Total: 2 [Remaining: 2]
00:00:30.843 -   Conversion of old Folders Completed. Total Converted: 2
 Error!
00:00:31.433 -   Application Upgrades : 07.01.01 Error!
00:00:31.783 -   Application Upgrades : 07.01.02 Success
00:00:32.043 -   Application Upgrades : 07.02.00 Error!
00:00:32.187 -   Application Upgrades : 07.02.01 Success
00:00:32.285 -   Application Upgrades : 07.02.02 Error!
00:00:32.342 -   Application Upgrades : 07.03.00 Success
00:00:32.350 -   Application Upgrades : 07.03.01 Success
00:00:32.356 -   Application Upgrades : 07.03.02 Success
00:00:32.551 -   Application Upgrades : 07.03.03 Success
00:00:32.609 -   Application Upgrades : 07.03.04 Success
00:00:32.614 -   Application Upgrades : 07.04.00 Success
00:00:32.746 -   Application Upgrades : 07.04.01 Success
00:00:32.748 -   Application Upgrades : 07.04.02 Success
00:00:32.754 -   Application Upgrades : 07.04.02 Success
00:00:32.763 -   Cleaning Up Files: 07.01.00 Success
00:00:32.768 -   Cleaning Up Files: 07.01.01 Success
00:00:32.772 -   Cleaning Up Files: 07.01.02 Success
00:00:32.776 -   Cleaning Up Files: 07.02.00 Success
00:00:32.780 -   Cleaning Up Files: 07.02.01 Success
00:00:32.796 -   Cleaning Up Files: 07.02.02 Success
00:00:32.801 -   Cleaning Up Files: 07.03.00 Success
00:00:32.805 -   Cleaning Up Files: 07.03.01 Success
00:00:32.807 -   Cleaning Up Files: 07.03.02 Success
00:00:32.811 -   Cleaning Up Files: 07.03.03 Success
00:00:32.814 -   Cleaning Up Files: 07.03.04 Success
00:00:32.818 -   Cleaning Up Files: 07.04.00 Success
00:00:32.820 -   Cleaning Up Files: 07.04.01 Success
00:00:32.826 -   Cleaning Up Files: 07.04.02 Success
00:00:32.828 -   Cleaning Up Files: 07.04.02 Success
00:00:32.834 -   Updating Config Files: 07.01.00 Success
00:00:32.843 -   Updating Config Files: 07.01.01 Success
00:00:32.883 -   Updating Config Files: 07.01.02 Success
00:00:32.925 -   Updating Config Files: 07.02.00 Success
00:00:32.952 -   Updating Config Files: 07.02.01 Success
00:00:32.978 -   Updating Config Files: 07.02.02 Success
00:00:32.992 -   Updating Config Files: 07.03.00 Success
00:00:33.044 -   Updating Config Files: 07.03.01 Success
00:00:33.060 -   Updating Config Files: 07.03.02 Success
00:00:33.078 -   Updating Config Files: 07.03.03 Success
00:00:33.097 -   Updating Config Files: 07.03.04 Success
00:00:33.121 -   Updating Config Files: 07.04.00 Success
00:00:33.143 -   Updating Config Files: 07.04.01 Success
00:00:33.179 -   Updating Config Files: 07.04.02 Success
00:00:33.197 -   Updating Config Files: 07.04.02 Success
00:00:33.212 - Performing General Upgrades
00:00:33.542 -   Installing Package File DNNCE_DigitalAssetsManagement_07.04.02_Install:<!--EndFragment-->
DotNetNuke <!--StartFragment-->
Server Error in '/dnndev' Application.
Value cannot be null.
Parameter name: source
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.ArgumentNullException: Value cannot be null.
DotNetNuke <!--StartFragment-->Stack Trace:
<code>
&#91;ArgumentNullException: Value cannot be null.
Parameter name: source&#93;
   System.Linq.Enumerable.FirstOrDefault(IEnumerable`1 source, Func`2 predicate) +4819894
   DotNetNuke.Services.Installer.Packages.PackageController.GetExtensionPackage(Int32 portalId, Func`2 predicate) +23
   DotNetNuke.Services.Installer.Installers.PackageInstaller.ReadManifest(XPathNavigator manifestNav) +794
   DotNetNuke.Services.Installer.Installers.PackageInstaller..ctor(String packageManifest, InstallerInfo info) +229
   DotNetNuke.Services.Installer.Installer.ProcessPackages(XPathNavigator rootNav) +299
   DotNetNuke.Services.Installer.Installer.ReadManifest(Stream stream) +399
   DotNetNuke.Services.Installer.Installer.ReadManifest(Boolean deleteTemp) +130
   DotNetNuke.Services.Upgrade.Upgrade.InstallPackage(String file, String packageType, Boolean writeFeedback) +354
   DotNetNuke.Services.Install.Install.UpgradeApplication() +682
   DotNetNuke.Services.Install.Install.OnLoad(EventArgs e) +386
   System.Web.UI.Control.LoadRecursive() +59
   System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +678
</code>
<!--EndFragment-->
There may be some information in the the log4net files in /portals/_default/logs. Look for the file(s) with "install" as part of the name.
Is this the same site as your other thread?
Yeah, this thread is part of main thread https://dnncommunity.org/forums/aft/1076/
I looked into log files . i see the same exception logged. i will try analyse more.
Exception details:
2020-05-26 17:48:32,783 [core6][Thread:22][ERROR] DotNetNuke.Services.Exceptions.Exceptions - System.ArgumentException: Version string portion was too short or too long.
at System.Version.VersionResult.SetFailure(ParseFailureKind failure, String argument)
at System.Version.TryParseVersion(String version, VersionResult& result)
at System.Version.Parse(String input)
at System.Version..ctor(String version)
at DotNetNuke.Common.Utilities.CBO.HydrateObject(Object hydratedObject, IDataReader dr)
at DotNetNuke.Common.Utilities.CBO.FillObjectFromReader(Object objObject, IDataReader dr)
at DotNetNuke.Common.Utilities.CBO.CreateObjectFromReader(Type objType, IDataReader dr, Boolean closeReader)
at DotNetNuke.Common.Utilities.CBO.FillListFromReader[TItem](IDataReader dr, IList`1 objList, Boolean closeReader)
at DotNetNuke.Common.Utilities.CBO.FillCollection[TItem](IDataReader dr)
at DotNetNuke.Services.Installer.Packages.PackageController.<>c__DisplayClass5.b__4(CacheItemArgs c)
at DotNetNuke.Common.Utilities.DataCache.GetCachedDataFromRuntimeCache(CacheItemArgs cacheItemArgs, CacheItemExpiredCallback cacheItemExpired)
2020-05-26 17:48:32,850 [core6][Thread:22][ERROR] DotNetNuke.Services.Upgrade.Upgrade - System.ArgumentNullException: Value cannot be null.
at System.Linq.Enumerable.FirstOrDefault[TSource](IEnumerable`1 source, Func`2 predicate)
at DotNetNuke.Services.Installer.Packages.PackageController.GetExtensionPackage(Int32 portalId, Func`2 predicate)
at DotNetNuke.Services.Upgrade.Upgrade.UninstallPackage(String packageName, String packageType)
at DotNetNuke.Services.Upgrade.Upgrade.UpgradeToVersion710()
at DotNetNuke.Services.Upgrade.Upgrade.UpgradeApplication(String providerPath, Version version, Boolean writeFeedback)
2020-05-26 17:48:33,152 [core6][Thread:22][ERROR] DotNetNuke.Services.Exceptions.Exceptions - System.ArgumentException: Version string portion was too short or too long.
2020-05-26 17:48:33,163 [core6][Thread:22][ERROR] DotNetNuke.Services.Upgrade.Upgrade - System.ArgumentNullException: Value cannot be null.
at DotNetNuke.Entities.Modules.DesktopModuleController.DeleteDesktopModule(String moduleName)
at DotNetNuke.Services.Upgrade.Upgrade.UpgradeToVersion711()
2020-05-26 17:48:33,608 [core6][Thread:22][ERROR] DotNetNuke.Services.Exceptions.Exceptions - System.ArgumentException: Version string portion was too short or too long.
2020-05-26 17:48:33,618 [core6][Thread:22][ERROR] DotNetNuke.Services.Upgrade.Upgrade - System.ArgumentNullException: Value cannot be null.
at DotNetNuke.Services.Upgrade.Upgrade.UpgradeToVersion720()
2020-05-26 17:48:33,753 [core6][Thread:22][ERROR] DotNetNuke.Services.Exceptions.Exceptions - System.ArgumentException: Version string portion was too short or too long.
2020-05-26 17:48:33,774 [core6][Thread:22][ERROR] DotNetNuke.Services.Upgrade.Upgrade - System.ArgumentNullException: Value cannot be null.
at DotNetNuke.Services.Upgrade.Upgrade.UpgradeToVersion722()
2020-05-26 17:48:35,227 [core6][Thread:22][ERROR] DotNetNuke.Services.Exceptions.Exceptions - System.ArgumentException: Version string portion was too short or too long.
2020-05-26 17:48:35,252 [core6][Thread:22][FATAL] DotNetNuke.Web.Common.Internal.DotNetNukeHttpApplication - System.Web.HttpUnhandledException (0x80004005): Exception of type 'System.Web.HttpUnhandledException' was thrown. ---> System.ArgumentNullException: Value cannot be null.
at DotNetNuke.Services.Installer.Installers.PackageInstaller.ReadManifest(XPathNavigator manifestNav)
at DotNetNuke.Services.Installer.Installers.PackageInstaller..ctor(String packageManifest, InstallerInfo info)
at DotNetNuke.Services.Installer.Installer.ProcessPackages(XPathNavigator rootNav)
at DotNetNuke.Services.Installer.Installer.ReadManifest(Stream stream)
at DotNetNuke.Services.Installer.Installer.ReadManifest(Boolean deleteTemp)
at DotNetNuke.Services.Upgrade.Upgrade.InstallPackage(String file, String packageType, Boolean writeFeedback)
at DotNetNuke.Services.Install.Install.UpgradeApplication()
at DotNetNuke.Services.Install.Install.OnLoad(EventArgs e)
at System.Web.UI.Page.HandleError(Exception e)
at System.Web.UI.Page.ProcessRequest(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
at System.Web.UI.Page.ProcessRequest()
at System.Web.UI.Page.ProcessRequestWithNoAssert(HttpContext context)
at System.Web.UI.Page.ProcessRequest(HttpContext context)
at ASP.install_install_aspx.ProcessRequest(HttpContext context)
at System.Web.HttpApplication.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute()
