Upgrading from DNN 9.3.2 to 9.9.1
Hi, I have recently upgraded my web site from DNN 9.3.2 to 9.9.1. I can reach the home page, but when I try to reach the CMS section I get the following errors:
2021-11-08 11:47:53,600 [HP-SMARI][Thread:65][ERROR] DotNetNuke.Services.Exceptions.Exceptions - DotNetNuke.Services.Exceptions.ModuleLoadException:  Unhandled Error While Adding Module to ContentPane. ---> System.NullReferenceException: Reference to an object not set to an object instance.
   in DotNetNuke.Modules.Admin.Authentication.Login.OnInit(EventArgs e)
   in System.Web.UI.Control.InitRecursive(Control namingContainer)
   in System.Web.UI.Control.AddedControl(Control control, Int32 index)
   in DotNetNuke.UI.Modules.ModuleHost.InjectModuleContent(Control content)
   in DotNetNuke.UI.Modules.ModuleHost.LoadUpdatePanel()
   in System.Web.UI.Control.EnsureChildControls()
   in DotNetNuke.UI.Containers.Container.get_ModuleControl()
   in DotNetNuke.UI.Containers.Container.ProcessModule()
   in DotNetNuke.UI.Skins.Pane.InjectModule(ModuleInfo module)
   --- Fine della traccia dello stack dell'eccezione interna ---
   in DotNetNuke.UI.Skins.Skin.InjectModule(Pane pane, ModuleInfo module)
Any idea of what kind of problem is this?
Did you go directly from 9.3.2 -> 9.9.1? Do you have any third-party modules installed? Do other pages function?
