Uploading files
Hi!
I have been updateing a DNN site from version 9.10.2 to version 9.11.0.
No errors in the update process and Telerik was removed successfully. The site works fine after update, but I can no longer upload files in Site Assets. The message shown is "Bad request".
In the site I can choose to use Swedish or English language. In the English part of the site the upload works, but in the Swedish part of the site it does not work.
In the "Server / Server Settings / LOGGS I found:
DotNetNuke.Web.InternalServices.FileUploadController - System.InvalidOperationException: Bad Request at DotNetNuke.Web.InternalServices.FileUploadController.UploadFile(Stream stream, Int32 portalId, UserInfo userInfo, String folder, String filter, String fileName, Boolean overwrite, Boolean isHostPortal, Boolean extract, String validationCode)
Does any of you in this forum know what the cause is?
//Peter
Have you tried reapplying the necessary file permissions to your website folder? Generally, the user account specified in the application pool for your website should have Modify/Full permission, and IIS_IUSRS should have read-only permissions (for static files like JS, images, etc.).
Oh, and if you choose to reapply the permissions, you'll likely need to recycle the application pool as well.  :)
Yes Will, I have tried that, just before I did read your input :) .
Unfortunately I was not able to fulfill the task due to errors like:
failed to enumerate objects in the container ... Access denied.
I could see that the files giving errors are new files from the upgrade and these files has the "owner" = the specified application pool.
When I try to update the permissions I am logged in as admin user on the server via a remote desktop. All older files has "owner" = the admin user, same as I was using when I when I was working on the server.
Perhaps I need to change the "owner" of ALL files in the website folder to the admin user, before I try to change the permissions?
I do not know how to do that. Can you help me out?
All the best!
//Peter
A few more thoughts,
I have not yet changed the owner of any file or folder, but all the folders and files I have inspected manually all have the permisson "Modify" for the apppool-user.
I have also seen that when I use the english part of the website, I have no problems uploading files in Site Assets. When I try uploading using the Site Assets in the Swedish part of the website I get the error.
//Peter
Posted By Smuggler on 10/18/2022 12:19 AM
Thank you for continuing to update this post with details.
At this time, it sounds like this might be a bug related to localization.  I found a few other recently reported bugs with the resource manager.  Do any of these look like they might be related?
If not, then more information is needed.  You'll need to determine if there are any underlying errors that are happening and use those to create a new issue in GitHub to resolve this localization bug.  :(
The following video can help you determine where and how to gather that information, except for whatever might be in the web browser console.
https://www.youtube.com/w...VcCY2yzhTZk&index=17
This page briefly describes the web developer console.
https://balsamiq.com/supp...faqs/browserconsole/
I have looked among reported issues but was not able to see any report beeing correlated to the problem I have seen.
I have now reported a bug with all information I have found on GitHub.
Will, thanks for your input and support!
All the best
//Peter
